I have a 2008 Solstice GXP with 35,000 miles with a 5 year 70K warranty still in effect and installed a Trifecta full tune on 11/7/2013. Everything was great and the car performed amazingly. Completed the data log and received confirmation on the data log back on 11/26/2013 stating:
Eddie Casselman,
A customer support staff member has replied to your support request, #582385 with the following response:
Everything is running to spec, no adjustments needed. For the backfiring, if you are using stock plugs at stock gap then a little backfiring can be considered normal.
We hope this response has sufficiently answered your questions. If not, please do not send another email. Instead, reply to this email or login to your account for a complete archive of all your support requests and responses.
http://badnewsracing.net/datalogs/[email protected]&a=f0d9c7c68af1a31e37af7a1a0c149b32
End of Response.
_______
As of 11/30/2013 I got a CEL and two codes of P0300 & P0304 for Misfire cylinder 4. I checked the plugs and coils and everything is in place and clean. I upgraded the spark plugs from the stock plugs to the NGK Spark Plugs LTR5IX-11 they were installed in the car back on 8/22/2013. Now when I drive the car normally under normal speeds you can't tell that there is anything wrong with the car. But when I step on the gas and the turbo spools, as soon as I reach 4K-5K RPM and turbo PSI reaches 19-23 then the car loses power and starts to stutter and I hear a popping sound coming from under the hood and some backfiring from the exhaust in the rear. As soon as this happens, the CEL lights up and blinks a few times then will stop blinking and stay on. Is there any advice you can send my way?
Eddie Casselman,
End of Response.
_______
