1 - 20 of 43 Posts
Solstice Footwell LED Kit! RGB Multicolor & Single color options! Control w/Phone!
Looking to add a fresh look to your Pontiac Solstice? Diode Dynamics' Footwell LED kits are the way to do it! By adding bright LED strips under your Solstice's dash, you can add a lot to the look of your Solstice.
Diode Dynamics has been producing and designing easy-to-install LED kits for nearly a decade, and this kit is no exception. We have designed new LED strips to be used in this kit, which are highly flexible, IP67-waterproof, and long-lasting. This kit also uses Diode Dynamics' RGB Multi-color products! You can change the color to fit your mood, or adjust the brightness to your preferred settings.
Included in the Diode Dynamics' footwell kit:
  • 2 (two) 30-5050 SMD Strips (flexible and IP67 waterproof)
  • Wiring harness for easy installation
  • 2 (two) quick-splices for installation
  • LED Toggle switch in your choice of LED color
  • RGB Controller Box with RF sensor and 4 outputs
  • Remote Control (choose Standard or upgrade to Bluetooth or WiFi)
  • 4 (four) zip-ties and 3M outdoor adhesive pads for mounting strips
  • Three-year Diode Dynamics worry-free limited warranty
  • 30-day satisfaction guarantee
Also included with rear footwell option:
  • 2 (two) additional 30-5050 SMD Strips (flexible and waterproof)
  • 2 (two) 3-meter (ten-foot) extension wires
  • Additional zip-ties and adhesive pads
Any questions email us at [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks!
Nick C.
DD,
I am looking for super bright LED s I can use to illuminate my under hood paint. Can you recommend something?
I am thinking about tiny spot lights or strobes that can be mounted to the firewall and be inconspicuous when not in operation.
Thanks
Rob,
We just added an Engine Bay lighting kit to our site. It will be plenty bright to show off your engine bay and is easy to install.
It's 10% off till midnight tonight with the code July
Nick C.
Most vendors would include a link to a product on their site so a customer could easily find it.
Just saying...
Just saying...
Okay, so where IS the under hood lighting on your site
Never mind then, because I went to your site and couldn't find it. I'll look at other options then, thanks. :thumbs:
Nick,
Thanks for the link
I looked at the under hood lights and while they are very nice, I am looking for high intensity spots that I can use to better light up the under hood painting. Bright enough to work in full sun light conditions. Because the hood opens forward, and generally the Punisher is parked facing into the sun to give the best natural lighting to the exterior artwork, the under hood area is generally in the shade. Its gloss black with a 4 foot punisher head in red with flames and as a result of ths shading and the high reflectivity, it is difficult to see at shows. I am looking to put a LOT of light up there .
Do you have any suggestions?
Nick,
Thanks for the link
Hmm...
These strips are definitely more of an "ambient lighting" solution vs. a full blown spot lot.
You might get the spot light effect you are looking for by adding one or two sockets in the engine bay somewhere and installing some LED bulbs, like a 921 or something.
You'll have to get something pretty bright to make a big impact during the day
Nick C.
Nick,
Feel free to pass this on up and down the chain of command if you wish.
I want you to know that I and perhaps others really appreciate your companies involvement here. We know you ultimately want to sell some bulbs; but I for one find it refreshing to gain knowledge that is seemingly unbiased (to my novice senses), and educate us about not only your products but especially on the testing proofs and things that should matter when looking for LED's etc. What you gain is an informed clientele that will remember your company. I've been to your site during one of the discussions where one of our geniuses pointed out a description mistake (methodology), and you or your company made no excuses, explained why you used the nomenclature for ease of understanding, but fixed it so the information was technically correct. This too bodes well in building trust and I wish all our vendors took that path.
No doubt this is the harder "sale" but is the most noble sale to gain valued repeat customers. I wish you all the best in your endeavors if you hold true to that paradigm.
In short you guys are doing it right, and I just bookmarked your site.
Keep up the good work.
Solo Dio
08 Solstice GXP Brazen / Inferno Orange
Discussion Starter #14
Nick,
Solo Dio
Thank you for the kind words Solo!
We are actively looking for a Solstice here in St. Louis to come in for product testing and comparison photos. It takes some time, and we got on the forum early to help members learn about lighting.
On an unrelated side note, I'm originally from Leawood, and will be in Kansas City on Friday for Fast Fridays at KC Trends (if it's this Friday)
If you able to make it, come say hello!
Nick C.
Nick C.
Make it? Huh I will fo shizzle now. I live in the development just north of there. I'll send you a PM of my cell number. Maybe I'll "show" my car.
Solo Dio
Discussion Starter #16
Solo Dio
I'm really excited to be there!
Our car is pretty tough to miss
If I install the single color kit, will it tun on when I open the door and then slowly dim when I close it? Just like the light under the mirror.
Discussion Starter #19 (Edited)
You can tap into that power source to have it operate with the factory interior lighting
Send us an email for more wiring tips: [email protected]
It will dim the same as your factory lighting, and come on with your dome/map light if you decide to wire it in that circuit
Nick C.
1 - 20 of 43 Posts
