181 - 192 of 192 Posts
Which Side? :brentil:
Oops, forgot to mention it was the driver's side. I didn't make the same mistake doing the passenger side haha
Edit: Just saw Gunny's response. Thanks!
Edit2: actually, looking at the description on a website, I think that's the wrong one I was looking for. When I said the interior door handle, I meant the part you yank on to shut the door when you're inside.
So, after some searching I've found the part number. It's 907916 for the driver's side in grey. Unfortunately it's no longer in stock anywhere. I may have to glue it :cryin:
What tabs could you break on the handle?
Yeah, so it's not the handle. It's the triangle-ish plastic piece under the handle you pull to shut the door when you're inside. Behind it is two bolts that you have to remove to take off the inner door liner. It's held on with three plastic tabs and one of those plastic screws that you just yank out instead of screw out.
Yep, that's the one Jeff, thanks! I searched on a bunch of websites and they only had ebony available. I'll try Tom on Monday. Thanks for the info!
15827960 seatbelt bezel driver side $4.07
19212670 performance upgrade kit $530.15
Part #907914 ebony $15.89 gmpartsgiant.com
*2009/10 Rear window glass hatch
*Note this is the glass coupe hatch P/N (not the rear window on the vert).
P/N 20823455
Dealership price as of 8/20/12
$875
Intake Cam Actuator connector - 13587320 $40.68
Exhaust Cam Actuator connector - 19178093 $29.59
Both of these are connector kits(?) available through GMPD
