41 - 60 of 192 Posts
Discussion Starter #42
Suspension Part Numbers Needed
All,
Really need suspension part numbers:
A-arms
Bushings
etc.
Discussion Starter #43
Bump, added 2006 ECM part number
Part Number
Just had the following part numbers installed under warranty to get rid of front & rear suspension squeaks:
Note: All are for Lower Control Arms, don't know what is front, rear, left or right:
15264321,15264322,15822072, 15264001
Discussion Starter #45
Thanks,
Updated initial post, and they were added in under Arm.
dsrtrmance gave you the part number for the rear valence:
i suggest you add an indication that this is the single exhaust.
and please add the gxp rear valence:
15254993......Rear Facia Panel GXP dual exit........................................... ...$230.90 MSRP
and a big THANKS for doing this, blake! :grouphug:
I plugged 15254993 into the gmpartsdirect site and got the following.
So I guess the dealer wants 230.00, but it can be got for less:
GM PART # 15254993
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $230.90
OUR PRICE: $136.86
Do we need two price columns: Dealer, and gmpartsdirect??
fred
Instrument Panel
Does anyone know the part numbers for the instrument panel? Interested in the panel only, sans gauges and controls.
There appear to be three different colors: ebony, seal, and gray. I'm not sure what I have--it looks gray to me.
Also, are there different numbers for the two variants--four switches vs. three--or did on supersede the other?
Discussion Starter #48
FredinVa,
My thinking was to show the benchmark price, so one can gauge if they are getting a fair deal on a part.
I agree with you, gmpartsdirect is the way I usualy go, which is kind of the unspoken reason for collecting part number in this thread. My main reasons I chose not to mention them is because I did want to break any forum rules.
GM PART # 15254993
CATEGORY: All
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $230.90
OUR PRICE: $136.86
fred
Discussion Starter #49
AustinTashis,
This is all I know from the list in the first post. I didnt know if you overlooked it or were looking for something else.
15805581......Instrument Panel Gauge Cluster.......................................$ 207.20
AustinTashis,
I don't think that's the right part. I think the gauge cluster is that cluster of gauges you'd be looking at if you removed that part I'm talking about, which is the surrounding plastic part that extends between the steering wheel and dash and extends over to the shifter boot.
I've got the part right here in front of me. For that price and that part number, you get:
the white plastic frame
the clear cover
the "gauge plate" which is just a piece of plastic with everything printed on it and shine through idiot light representations
the 3 needle indicators
the odometer, which is set into the white frame and shines through the plastic.
I thought the odometer was built into the DIC.
Anyway, that's not the part I'm looking for.
The part I am looking for is the gray plastic part shown in the middle three pictures in this post.
What you're describing sounds like the first picture in this post.
OK, I think we're on the same page now. You're talking about the face of the dash that extends from the gauge cluster to the double vents down to the radio and finally to the gear shift, right?
And you want to change that to a different color? That part number is not listed, but any GM dealership can look it up for you. They have blow-ups on their computer to show you what the part looks like and then they pull off the part number. You don't even have to order it right then, just get the part number.
So, I'm going to delete all my posts about the gauge cluster, since they have nothing to do with the subject at hand.
Right
No, I want to get a new one in the same color. I want to make a hole in my dash to mount a radar detector, and possibly move the airbag warning light to a less obtrusive location. I thought this would be easier and less stressful if I could work on a new panel and swap them out when everything's ready.
Yeah, I'm probably going to have to go to the dealer to get the part number. I was hoping someone might know it. I probably won't buy it from the dealer, because I've found it online for $155, but they have three colors and I don't know which one's right. I'm not even sure if it's the right part because they don't show a picture.
Yeah, I saw that. Not my cup of tea.
Discussion Starter #54
AustinTashis,
Sorry for the confusion, looks like you and Gizmo sort things out already.
If you find the part#, please keep this thread in mind so we can update it with this info.
Hmm........ try one of the 1st 4 on this list.
Part No. FNA Description Color Name Options
15912960 PLATE ASM-I/P CSTR TR DK GRAY MET &VGL&19I.
15912961 PLATE ASM-I/P CSTR TR V DK STL GRA &VGL&31I.
15940684 PLATE ASM-I/P CSTR TR DK GRAY MET &19I-VGL.
15940685 PLATE ASM-I/P CSTR TR V DK STL GRA &31I-VGL.
15867067 HANDLE ASM-I/P ASST V DK STL GRA &31I.
15867060 BEZEL-I/P ASST HDL DK GRAY MET &19I.
15867061 BEZEL-I/P ASST HDL V DK STL GRA &31I.
15855546 MODULE ASM-INFL RST STRG WHL V DK STL GRA &31I.
15254355 MOLDING ASM-W/S UPR GARN MD STEEL GRA &31I.
Discussion Starter #56
Manch-GTA,
Is this all Dash Trim?
Manch-GTA,
A lot of those numbers don't get any results when I search for them on the online dealer sites, and when they do the descriptions are even more cryptic, and of course they never have any pictures of them.
I might take this list with me when I go to the dealer.
You better believe its all Dash.
I/P in GM lingo is 'Instrument Panel' (or dash).
I will decipher the item below for you as best as I can.
(Plate Assembly, IP Cluster Trim Dark Grey Metalic (19I is the code for that)
(Plate Assembly, IP Cluster Trim Very Dark Steel Gray (or 31I code)
(Handle Assembly IP Assist - Dark steel grey - this is the small handle trim on the dash).
Bezels - IP Assist Handle
(molding assembly for Windshield Upper Garnish (steel gray))
Hope these help. You will have to x-ref this info with a Dealer to get a quote.
If the part number no longer exists, it may have gone through a revision.
But if you got the part off already, did you check for the part number on the physical part? GM normally forces suppliers to mold in the part number on the back of the part.
Does anybody have the part number for the base cat converter??
