161 - 180 of 192 Posts
Anyone know the part numbers for the following Sky Redline 2.0 Motor components
Main Rod Bearings
and any other bearings
PM is also fine.
I am looking for the part numbers for the left and right pillar that the tweeters are mounted in. I have a sky but the numbers should be similar.
Thanks
Matte Black Replacement Grilles
I want to purchase stock matte black front grilles (like the lighter color GXP's have) to replace the silver grilles on my 06 NA Solstice. Part numbers 15265486 & 15265487 are Solstice grilles but there's no way to tell the color at either gmpartsdirect.com or buy-oem-parts.com. Naturally, my dealer can't tell, either. I'm pretty sure they are interchangeable, though (just the large grilles, not the small foglamp grilles).
Anyone know definite numbers for the matte black grilles as opposed to the silver ones?
Thanks very much.
does anybody knows the part# for the GXP Blow Off Valve?
There is a bypass valve, but it is integral to the turbo. You can only replace the diaphram, or I think there may be a kit P/n 19168558. The bypass valve is actuated by vaccuum, so there are replacement parts for the actuator, etc., but not a discrete blowoff valve like you are thinking about.
Hey, looking for the OEM part# for the rear waterfall panel that has the subwoofer grille. Thanks:thumbs:
Oh boy. There is a part number for each color car and interior plastic color variant. You need to know your exterior color and your interior color scheme (grey, ebony or cashmere, for example).
Hi
would anyone know the part number for the rubber air deflector and the rubber panel that connects to the front bumper Cover (nose) right under the front plate?
If you hit a parking curb its the first parts to get scratched
thanks
10345219.
Main Rod Bearings
PM is also fine.
12591093 shows as a Bearing Kit, Conn Rod (standard size, full set).
12591092 shows as BEARING KIT, CR/SHF, and appears to include all of the crank bearing parts.
Thanks
Ebony parts for 2008-2009:
25956187 (UE1, 02I, 19I, 31I)
25956185 (02I, 19I, 31I)(EXC UE1)
are shown for Left. I think UE1 is onstar?
25939751 for Right.
15826614 Left (GRAY) (UE1, 31I) 2006-2006
25956187 Left(EBONY) (UE1, 19I) 2006-2006
25956185 Left(EBONY) (19I)(EXC UE1) 2006-2006
25939751 Right(EBONY) (19I) 2006-2006
25855763 Left(GRAY) (31I)(EXC UE1) 2006-2007
15912030 Right(GRAY) (31I)
SKY 2007-2009
25939747 Left
25939751 Right
Anyone have the part number for our Tail Lights ?
15918196 and 15918197 should be Solstice Tail Lamp including the bulb and socket.
Thanks very much.
All GXP have the black grilles. 15265487 and 15265486 should be the Left and Right GXP (black) Grilles. The base car uses 15909804 & 15909805 (Right and left) Silver Grilles.
I was wondering if anyone had the part numbers for any of the hoses in the engine bay, i seem to not be able to read mine
Bit more specifics, please. Pictures with arrows are even better. There are coolant hoses, turbo hoses, etc.
coolant, vacum, heater,fuel. Im trying to get steel braided hoses for just about every hose that I can replace and need the numbers to give the company so they can make exact fit ones. I have to figure out how many of each I need.
Thanks
There appears to be a piece which fits between the rear of the driveshaft and the differential, and attaches to each with three bolts. Is this the "companion flange"? Does anyone have p/n's for these pieces? BTW, I don't have a Solstice-I'm building a Lotus 7 replica with the Solstice drivetrain.
thanks
Buttress release cable. This is the cable that releases the convertable top buttresses from the trunk lid. I just had mine replaced in warranty.
Part number # 15805321 Around 60 bucks depending who you get it from. I don't know if the car uses two. Only one was installed on mine but only the driver side buttress failed to release. I suspect there may be one for each side.
Air Filter Element for Stock 2.4 N/A
GM part # 15287103 Around $25
From the 2006-08 Solstice collision manual.
3 Bezel, Air Outlet – R/L 10392990 (the chrome outer ring)
4 Outlet, Outer Air – R/L 15824746 (Center tube with vents I think you're asking about.
5 Seal, Air Outlet – R/L 89046321 (self explanitory)
:thumbs:
Long shot since this is kind of an old thread, but does anyone know the part number for the triangle shaped piece that's right by the interior door handle? It's the part that pops off to access the bolts to remove the interior door cover. I didn't realize that it had plastic tabs and of course I broke all of the tabs the first time I removed it hah!
Which Side? :brentil:
Plug, Door Handle Interior
Ebony R-15852769
L-15852768
Gray 06-07 R-15852771
L-15852770
