1 - 5 of 5 Posts
Well plx gauges suck, have to send them back, in the press the power wire grounded, know the service air bag light, no power to ac, fan works, no power to radar, plx guauge, and wipers, look st every blade fuse, can't figure this out, I would think they are all on the same circuit, any thoughts
Did you check the fuses under the passenger floor board?
Yes, I found that box, can't really test the big fuses, off to the dealer, it has to be simple fix
Found the problem, accessory switch, seems to control a lot of stuff, would think the car would not start, it does, just all the wipers, airbag and ac did not work.
I have wipers that don't work. Only wiper function that works is manual 'push to wash' on end of stalk and associated wipe. AC seems OK. Could the accessory switch be involved and where is it located?
1 - 5 of 5 Posts
