I have to admit that I have not read every thread on the Forum, so this may be out there...
Last weekend I went out to cut the grass on some property we own and the mower had two flat tires.
Light bulb went off that since I was in the Solstice I could just use the pump that has been in the trunk and not moved since I bought the car. Saved me a trip back home with the trailer to get the big compressor.
First off the pump worked great to get the mower going.
Second as the pump was working I looked at the attached fix-a-flat canister and noticed it had an expiration or use-by date. Since I have a 2009 Coupe I have one of the later models so should have the newest pump... The expiration date was April 2013, not sure if that is just recommended or if that means the stuff magically turns to sludge, but thought it was worth passing on for others to check.
Not a big deal for me since i never plan to pump the gunk in my tires, but someone may be stuck in a place and need it. So I would recommend that you all take a look and see if yours is expired too and then do your own risk assessment if you want to update that small canister or rely on a flat-bed wrecker when you have a flat on the road.
