Okay, well I have referenced my issue in another thread stating my concern about the closeness of our cars to the ground. So this an on-going thread of suggestions and feedback for what has worked for some individuals.
Background information: Our cars' front bumper (well most anyways) have a clearance of about 5 inches off the ground and the air dam (i'm calling it an air dam, not sure of the proper terminology, feel free to correct me on this) being about an inch or two off the ground. In effect, when we drive (most of the time off rather than on) off/on driveways/speed bumps/any other abnormal surface in the road we often hear that sound that makes us cringe for our car's health. THAT SCRAPING SOUND!!
So let's address the problems and the possible solutions:
My background information: I drive a N/A (I believe N/A refers to non-GXP in this forum) 07' Pont. Sol. and almost every time I drive off my driveway I hear the bottom lip of my front bumper scrape against the concrete. I have avoided this scraping maybe once or twice, but I have no idea how. My driveway's about 2 inches off the street and my garage is about 2 inches off the driveway as well.
Some pictures: https://www.dropbox.com/sh/9oweugvhyboysku/TfEQ73I3qx
Starts with some basic and then into measurements (all referenced above). I took 2 driveway pictures, one of each end to make sure it was leveled and that I didn't somehow drive too close to one end which caused me once or twice not to scrape my bumper.
Here was a post from the previous thread:
Others have suggested angling the car when backing out (slowly) so the front wheels do not land on the street at the same time. I have tried this tactic earlier this morning and have had no success, but one test cannot prove it so I will test this the remainder of the week and report back.
Another suggestion was a driveway ramp; however, agreeing with Charlie, I do not believe my area of residency allows this sort of "street modification" so that is a no-go.
I am considering either sanding down my front bumper's lip or sanding down my driveway's curb a bit to allow no-scrape. However, this will not address those nasty speed bumps and other bumps in the road. So, we need more suggestions, more feedback, and more problems!!
Thanks.
Charlie (TX08manualGXP): this lip cutting, that's my bumper correct and not the driveway? If so could I just sand it down or would I take other precautions.I can enter my driveway without scraping but backing out is about a 50/50 chance. I guarantee your home owners association will NOT allow you to use one of those ramps but you can get away with pouring one out of concrete. However, if it affects water drainage then the city will come remove it. I don't see why you couldn't cut about 1/2 inch off of the lip. might be worth a try and prevent it from catching on something and ripping the whole thing off.
Thanks.
