I've been having quite a few issues with my car over the past few months - when I first received the car, it still had the original battery, so I had that replaced back in March of this year. A day later I got a low battery light on my gauge cluster (I am sure it was the low battery light, not coolant as recommended by others with similar problems). It came on and off sporadically. I figured I was probably due for an alternator since the car started needing to be jumped to get it to turn on. I purchase a brand new alternator, installed it, jumped it once to get the battery up to CCA, and all was good for several months of driving, during which the only problem I was having was an O2 sensor CEL that I fixed by replacing that.
I got my car inspected a couple days ago, passed with no problems whatsoever. As I'm driving home from the shop, the ABS light comes on - I've never seen it before. Goes off almost immediately. I figured it might just be from some test they ran. Later that night I'm driving to a friends house that I have to take the interstate to get to, and suddenly the battery light comes back on for the first time in months. A minute later, the stereo starts flickering and then looses power. At this point I decided I'm heading home. It then gets even worse - the ABS light comes back on, shortly followed by the service airbag light. All those lights take turns showing themselves on the gauge cluster, only to be trumped by the entire gauge cluster shutting off - I'm driving down the interstate home and can't see my speedo or tach. The drive by wire system is somehow still working fine, and I'm able to get the car safely home without any information as to what I'm doing. When I arrived, I thought surely the battery wouldn't have an ounce of energy left after all the encounters I just experienced. But to test, I turned the car off once parked in my garage, turned it back on, and the engine started with no problem whatsoever.
This all comes after a once every other week / weekly complete failure to start that I have been experiencing since December - before any batt/alt problems were had whatsoever. I'll turn the key to crank and it will just be complete silence. Lights come on fine, clutch safety switch works fine, and yet nothing. No solenoid click, no crank.
TL;DR: brand new battery, alternator, oxygen sensors, exhaust manifold (just because the old was cracked), car runs and drives perfectly & smoothly with no warning lights, got it inspected, passed, then all of a sudden just about every electrical system stops getting power + battery light comes on. Get home and power cycle it, starts just fine.
Any information or troubleshooting advice as to what is going on would be incredibly appreciated!
