1 - 6 of 6 Posts
We do not have failure detection for most of the lamps. The only place you will have a problem is with the stop/turn signals, where LEDs will result in hyperflash unless you use resistors.
I figured as much, anything that goes Blink Blink. Thanks JohnWR. anything we can do for DRL? Not a big deal, it just defaults to normal light mode instead of low power.
It may be a problem... the DRL mode is lower voltage, and that could cause reliability issues with your LED drivers.
The following is a relatively easy option, if you want to switch the DRLs to the fog lights instead (full power): Simple reroute DRLs to Foglights mod (for HID users)
Who are you and what have you done with Soup???? No, "you're going to blind people"???? ;) Have you given up? Say it ain't so!!!
1 - 6 of 6 Posts
