1 - 2 of 2 Posts
This has been a ongoing problem. from time to time the steering wheel will squeak at low speeds or feel like its rubbing. it stays for a few days and goes away. It also makes a squeak sound when i press on the brakes and clutch pedal and i did try the spray lube. im not sure if that's why it goes away or not. I only have a month left on the gm warranty and was wondering if it may be covered.
Better or worse at higher or cold temps? Where did you apply the spray lube?
When you say "it also makes a squeak sound" when you press the brake and/or clutch, do you mean the steering wheel squeaks when you press them?
1 - 2 of 2 Posts
