1 - 7 of 7 Posts
2007 solstice gxp automatic 27000 miles,has larger turbo,stage 3 tune,solo cat,larger intercooler,upgrade charge pipes,tcm reflash,big shotair intake.
The problem is while driving the engine shut off,gauges and lights work,wont turn over ,does nothing fuses and relays checked,new battery,turn key to start position lights and gauges go off and no crank. Has anyone had that problem and what was the fix.(please help.
You need to find out what codes were set before venturing into a guess as to what could be wrong.
Has this happened more than once, or did it die and hasn't functioned since?
As LV asked: Are there any codes, and if so what are they?
Who did the tune and TCM re-flash, and how long ago were they done?
Have there been any other issues/symptoms/problems?
When you turn the ignition switch to the start position can you hear the starter solenoid click or just nothing at all. Could be the battery connections or a loose or corroded ground connection. Like LV said, you need the codes or it is all just guesswork.
Discussion Starter · #5 ·
Problem fixed,as the main harness had dropped down on alternator and cut through to ecm wire and then blew fuse,repaired and runs fine.
Glad you found it, and thanks for the update!
1 - 7 of 7 Posts
