So my clutch line was rubbing against the body seam and eventually caused a failure. If any of you had had to replace that line, you know you have had to remove the transmission in order to disconnect the one end from the slave cylinder. Well I wasn't looking to spend the day pulling the transmission AGAIN. So I sent a message over to Dave at Performance Autowerks and asked if he had any solution. In true Dave form he responded with a resounding "Ya, I know how to save you a ton of time." Basically you cut out the bad rubber part of the line and install compression fittings to the nubs of hose you have left and drop a braided line in between the two connectors I found a local supplier and had the car fixed in under an hour. So thanks again Dave for saving the day.
Sent from AutoGuide.com App
