1 - 8 of 8 Posts
I have a 06 supercharged 2.4 automatic. I went to go drive it and when i got on it the car started to miss and i then let off and the check engine light started to flash and then it went away but the car still ran fine.Then the car started to downshift really hard. I got home and let it sit for a few minutes and drove it again and it was fine. What do you guys think the problem is? spark plugs, o2 sensor, clogged cat.
Also got to change cracked solo header this weekend again.:brentil: im done with their headers im just putting the stock manifold back on.
It could be a few things, you really need to try and get the code when it appears.
I have the same set up you have, 06 auto S/C.
Let me know what codes are coming up.
Thanks
I'll hook up the scanner tomorrow and see if i got any codes. could a cracked header make me lose horsepower? it just seems i don't have the same amount of torque.
1 - 8 of 8 Posts
