1 - 5 of 5 Posts
I purchased some switchback for the front markers. They came with inline resistors. Trying to figure out which wires on plug do they need to be connected too.
I don't think it would matter as long as it is in series. It would still limit current. More info might be helpfull.
Need the wireing info for the front blinkers.
Put it on the more positive lead ,should not really make much of a difference.If you think of a resistor like a water line in a loop and you used the resistor in that loop somewhere the return flow would be restricted ie:resistor. I always put resistors in front of a load rather then the return.
1 - 5 of 5 Posts
