1 - 3 of 3 Posts
36 steps,
1.Remove the intake manifold cover. Refer to Intake Manifold Cover Replacement .
Remove the oil level indicator tube. Refer to Oil Level Indicator and Tube Replacement .
Disconnect the fuel feed line quick connect fitting (1) from the fuel rail. Refer to Metal Collar Quick Connect Fitting Service .
Disconnect the evaporative emission (EVAP) line quick connect fitting (2) from the EVAP purge solenoid. Refer to Plastic Collar Quick Connect Fitting Service .
5Reposition the brake booster vacuum hose clamp at the intake manifold.
Remove the brake booster hose from the intake manifold.
7Remove the knock sensor electrical connector (1) clip from the intake manifold brace.
Remove the knock sensor electrical connector (2) clip from the oil level indicator tube bracket.
9Disconnect the engine wiring harness electrical connector (1) from the EVAP canister purge solenoid.
Disconnect the engine wiring harness electrical connector (2) from the manifold absolute pressure (MAP) sensor.
Disconnect the engine wiring harness electrical connector from the charge air bypass vale solenoid.
12Disconnect the engine wiring harness electrical connector (1) from the throttle actuator control (TAC) module.
Remove the engine wiring harness clip (3) from the intake manifold brace.
14Reposition the surge tank air bleed hose clamp at the engine (1).
Remove the surge tank air bleed hose from the engine.
Remove the surge tank air bleed hose clip (2) from the surge tank bracket.
Reposition the surge tank air bleed hose out of the way.
18Reposition the charge air bypass valve vacuum hose clamp at the intake manifold.
Remove the charge air bypass valve vacuum hose from the intake manifold.
Remove the charge air bypass valve solenoid bolts.
Reposition the charge air bypass valve solenoid assembly out of the way.
22Remove the surge tank bracket bolt (1) and stud (2).
Remove the surge tank bracket (3).
Remove the surge tank hose retainer and hose from the surge tank bracket.
25Disconnect the metal quick connect fitting from the fuel feed pip. Refer to Metal Collar Quick Connect Fitting Service .
Disconnect the fuel feed pipe fitting from the fuel pump.
Remove the fuel feed pipe bolts.
Remove the fuel feed pipe.
Inspect the fuel feed pipe nut for damaged threads.
Inspect the fuel feed pipe sealing bail for damage or debris.
Replace the fuel feed pipe if any damage is found.
32Unbolt and reposition the power brake booster pump. Refer to Power Brake Booster Auxiliary Pump Replacement .
Remove the intake manifold brace bolt.
Remove the intake manifold brace.
35Remove the intake manifold bolts and nuts.
Remove the intake manifold and place on a clean work surface.
Important: The intake manifold gasket is reusable. Only replace the gasket if damage has occurred.
Simple!
1 - 3 of 3 Posts
