Ok,
I have been having the elusive disappearing coolant for about 6 months now. At first it was only a tiny bit, maybe a inch or so every couple months. Had the system pressure tested and they said there was no leaks. So I figured I would wait until it got worse. Well now I am losing 10 times that now and now we can finally see where it is coming from. It's leaking from the water pump, but not the weep hole, its seems to be leaking from the gasket or the body of the pump itself. I have heard there is a new design on these and want to make sure that if I tear it apart again, I am putting in the best pump that is available instead of another crap one. Any help on part numbers would be appreciated.
Tony
Tony
