1 - 16 of 16 Posts
Had posted earlier about Camshaft Position Sensor - My wife has a 2008 Solstice GXP with 90k miles on it that just quit on her on the road. I brought the car home, checked to see if it cranked & had ignition & gas - all seemed ok. did compression check - sort of ok on 1 3, nothing on 2 & 4.
Pulled off the timing cover and noted a loose timing chain, so I have a timing set on order.
Am I wasting my time doing this or is there a chance that replacement will fix this? I'd rather spend a couple hundred and a weekend than the cost and effort of a replacement engine. Are there other checks i can do before tearing into this?? I ran a USB camera down the spark plug holes to look at the pistons and hard to tell if there has been any valve / piston collisions or not. Lots of carbon buildup.
Can anyone point me to a good step by step timing chain set replacement procedure for this vehicle? What all has to be pulled out in front of the engine to do this- hood, radiator, air intake ?? I'd like to pull as little as possible.
Also, are there any specialized tools?? All that comes to mind is a harmonic balancer removal tool.
thanks in advance,
Michael
Ft Worth TX
817-845-4241
If you really do not have a any compression on cylinders 2 and 4 then is an engine rebuild or another engine new or use.
Reactions: CABGX5
If you have no compression on two cylinders it sounds serious. our engines are interference engines and if the timing gears have slipped out of time or the chain has broken, you could have destroyed valves, pistons or both. If you are getting even low compression on all four, it may not be so bad.
There is a video on youtube. i think it is titled ECOTECH TIMING CHAIN REPLACEMENT that will give you a pretty good idea of what is involved.
check that compression again and good luck.
Bill
This is a zero tolerance motor, so if the timing chain is that bad, you might have crushed the valves.
Discussion Starter · #7 ·
I've been told that I'm very likely looking at bent valves and minimum head removal to fix. I'll turn the crank to see of the chain gets tight - I suspect it will.
What's the best source for a manual for this car to know best way to go about this??
Also, having not done one of these engines before, what do I need to be concerned about and what if any special tools are needed?
Thanks in advance,
Go to helminc.com and buy the factory service manual. The last time I looked the set was $300.
this is your best bet. I got mine on eBay for about $250.00. it is a three volume set and altogether is about 8" thick. well worth the money.
No compression can be caused by a few things:
- Bad rings. Unlikely in your situation, and you'd typically see low compression, not zero. And, having rings on two cylinders suddenly die would be pretty surprising.
- Head gasket. Same as above. Also, you typically see low compression on adjacent cylinders, not on two that are not adjacent.
- Valves not closing, possibly due to broken valves, broken valve springs, bad guides, etc. It'd probably be smarter to replace the head then to try and rebuild it in that case. But, having broken components on just two cylinders is unlikely (but certainly not impossible).
- Cams (and therefore valves) are out of sync with the crank due to the timing chain jumping. This is pretty hard to do without, at minimum, trashing the valves. The reason you'd see low compression on cylinders 1 and 3 but not 2 and 4 (or vice versa) is that, if the cam is, say, 90° out of phase, then the valves would be open while the piston is on its compression stroke. The even cylinders are 180° out of phase with the odd cylinders.
In order for that to happen, the timing chain would have to jump - a LOT - or the cam gear would have to come loose, allowing it to rotate without moving the cam sufficiently. If your timing chain is loose enough - I'm guessing due to a bad guide or tensioner - this could happen, but may end with the pistons slapping the valves. That would certainly destroy the valves and probably won't make the pistons happy, either.
In any case, the head is going to have to come off. Just installing a new timing set will not correct the problem.
A replacement LNF will run you about $2400. ATK is a very reliable supplier. Installation isn't difficult if you have the space and tools, but it does take some effort. (Duh.)
Remove your intake and look at your valves, it only takes 10 min. As Raygun stated, the ATK engine is easy enough to swap out, I just did it. I burned a hole through piston number two, and had zero compression at 37k miles, I think youre more likely to have bent valves.
Well, sure, if you want to do it the easy, direct and most efficient way.
But, getting the intake manifold took just a bit longer than 10 minutes for me the first time. It’ll have to come off in any case to remove the head, so may as well start there and inspect the valves.
Good call.
Reactions: SolCal
Good call.
Hah, thanks for reminding me. It definitely took me much longer to remove the intake the first couple go rounds!
cloyes has a good utube vid and great timing kits too, not the cheep china stuff. your more than likely gonna need a set of valves too.possiably a valve job...possiably a new head quite a few posibilitys. but just timing chain aint gonna fix it. you could pull the valve cover and see if there is loose rockers on those cylinders when the lobe is off the rocker arm, check them all, if they are loose then yup those valves are bent.hopefuly the guides did not get cracked or seats get whaumped.
1 - 16 of 16 Posts
