Swapping a '06 Solstice Engine and 5-spd Trans into my heavily modified '61 Volvo
Naturally.... the junk yard got everything blown apart before I could snag it....
- loosing all the bolts....
So I decided to go to the dealer to make sure I got the correct factory bolts to put back together with confidence.
Need torque specs for:
1. flywheel to crank:
2. pressure plate to flywheel (stock clutch/plate):
3. Transmission bellhousing to engine block:
Thanks
Thanks
