1 - 11 of 11 Posts
Traction and Stability control is an option available on the MX-5 Miata, but not on the Solstice. I also see that many cars also offer this option. Since the Solstice is a roadster, shouldn't it have been offered as an option? Now, I want to get the general opinion, about whether Traction and Stability control are important in a roadster. Also, the Solstice does have an option for ABS brakes, and Limited Slip Differential. I've heard those offer some sort of traction and stability control, but is that true?
Isn't traction control available on the Sky?
Electronic traction control doesn't really fit with the whole "back to basics" concept :yesnod:
... of course, neither does ABS ;)
I have traction control on my Bimmer and I really noted the lack of that sweet gizmo driving the Solstice hard in the curves. The back end does get loose if you kick it hard. But for a car that was designed for the $20K bracket you have to leave off the fancy electronic gizmos like traction control. You get what you pay for and not a nickel more...
Limited slip is not the same as traction control where selective braking is applied to keep the rear tires glued to the pavement.
Hey! That was MY Solstice you were driving! :brentil: :cuss:
:glol: You took me pretty seriously when I told ya not to worry about beating on it, huh? Good. Did I even tell you that mine doesn't have ABS? Did you figure it out? Just so ya know next time, it has no ABS ;) Check it out, just don't flat-spot my tires... well, I DO want new tires :devil:
I've never had traction control until my Boxster. I've had it for a couple of weeks and I must say it is a confidence booster. I have been able to break it loose...I did get a wee bit of four wheel float one time...I haven't driven in wet weather to see how what the impact is in such conditions.
HUH? Did somebody call me? Oh, I guess not. Back to sleep. zzzzzzz :leaving:
I've found that good tires, antilock brakes, and a locking rear are pretty much all you need. The high end dynamic stability control on the Vette is nice but with only 170 horsepower I don't think it's necessary. The extra weight and cost won't be missed for most Soltice owners.
If you need tracton control, you probably shouldn't be driving a RWD roadster. With the 5-speed you can add as much torque as you want with different gear selection. A 2nd gear or even 3rd gear start in my 600 horsepower Camaro helps me survive the winter commute. I keep the stability control off in my Camaro in the snow because I can't get anywhere with it on.
Ahh one of the two secrets to accellerating from a stop in snow. The other is "don't stop."
...but with the gear-ratio spread in the Solstice, I don't think a 3rd gear start would be easy.
1 - 11 of 11 Posts
