Grateful for any advice:
I accidentally mistook the transmission pan plug for the oil plug.
Sounds like I only drained about a third of my transmission fluid from what I've read; issue is I drained it into the cutout 5 quart container I use for oil changes.
There were a couple of spoonfuls of used motor oil in the container that likely got into the transmission fluid, and I put the fluid back into the transmission.
It sounds like a transmission flush will do more harm than good. The car has never had the transmission fluid changed before.
I haven't run the engine yet.
Should I change the transmission fluid, or is that small amount nothing to write home about?
