1 - 3 of 3 Posts
Hey guys I recently installed a catless DP and trying to avoid installing a downstream 02 extender by disabling P0420 in trifecta. It works for a day and then the CEL comes on with the same code I disabled. when I hook it up the setting shows all codes active. Do you know why it doesn’t save? I have the tune itself programmed to turn off and on via the cruise control button. Thanks in advance.
Why would you care about the downstream sensor? Just install the extender so it won't throw a code and forget about it. A lot less fuss than you are having trying to circumvent it.
1 - 3 of 3 Posts
