1 - 9 of 9 Posts
Hi!
I have a problem with trunk open mechanism but i don't know how to "open" for access to it. It is near the 3rd stop light.Anyone can help me?
Thank you very much!
M.
I believe that what you want to access is easiest to get to if you remove the rear bumper cover. I could be wrong though because that picture you posted is too dark and grainy to really see anything.
What problem are you having that you need to get access?
You really need to tell us what you're actually trying to do. You can access the stop light by removing the license plate light (2 screws above the plate itself) and then reach up. You can disconnect the wiring connector from there. If you want to remove the light itself, be warned that it's both 'glued' (3M-type foam tape) and clipped in. If you are replacing it, just cut the tabs off and use a hair dryer (or similar) to soften the glue before carefully levering it out.
i have a problem with trunk open mechansem. It have a part broken and this part is located near the 3rd stop ight. It seems impossible to release the 3 screws :) It is no space.
1 - 9 of 9 Posts
