when i push the button, to open the trunk , it dont want to open , seams tostick , haver to pry on it to get it to opne , any one know why this would be , Thanks , I am new to all this .
I have a slightly similar issue, my passenger side wing doesn't pop out with the trunk. I have to push the truck back down slightly on that side before it releases, then pop the trunk again to open it.
If the buttresses release but the trunk lid does not pop up, verify the fit and if it's good then check the torsion bars. One of them may be broken. Mine were very weak and the trunk would not stay open. I replaced them and adjusted the stops under the bumper cover and not it pops open and stays open. It's in my thread with pictures if that helps.
if the top is not stowed fully down you will have a hard time making it release.push down gently but firmly on each side of the top before shutting the trunk,thatll help.i had this problem the first few times i drove my car.
my 06 got to where it wouldn't pop open by itself and I ended up bending the bracket on the latch down just a tad which made the cable tighter and it's been fine ever since. Pretty easy fix once you figure out the mechanics of the latch. small tweak with pliers and it's a done deal.
A forum community dedicated to Pontiac Solstice owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, maintenance, trade parts, and more!
