Status
Not open for further replies.
1 - 2 of 2 Posts
www.nhtsa.dot.gov said:
Technical Service Bulletins
The Technical Service Bulletins Search Engine will allow searches of summaries of the Manufacturers' Technical Service Bulletins by single year, make and model. An optional item of Vehicle Component may be selected to help narrow the focus of the search. (The data does not contain all the service bulletins generated by a manufacturer. Bulletins for safety recalls in general are not included, and also bulletins which may not pertain to a defect may not be included.)
Considering the above caveat, that site lists (as of 8/20/07) the following tsb's for the 2006 and 2007 Solstice.
Check the descriptions attached and if you feel that your car 's actions relate to what is described it may be possible to save the service department some time in diagnosing and solving a problem.
Please note that these lists are not complete and individual TSB's may be superseded or replaced by service manual information.
Also please review the (following) explanation of several listed tsb's which even though tagged to the Solstice, DO NOT APPLY TO THIS VEHICLE.
Since I have a few problems with my car, and it is in the dealer now getting fixed, I might as well list the TSB's that could correlate to my issues:
or could not..........
07-06-04-010A- Starter Cranking Issues
Not a cranking issue, the bulletin is for cars that do crank, just do not start. Basically for dealership inventory vehicles (2007 early build GXPs) that are repetitively started and driven short distances/short times.
01-06-04-010B- Starter Cranking Issues
No bulletin found with this number. Did find the original 2001 bulletin #01-06-04-010, which was issued about changes in the 1999-2000 Geo Tracker.
04-07-30-013B- Automatic transmission Driveability/Clunk
Applies to all GM vehicles 2007 and prior. Advises dealerships to not repair under warranty a list of issues that can be caused by excessively/over oiled aftermarket air filters.
07-07-30-008- Automatic transmission Production Update
Only applies a 2005-2007 GM RWD 4-speed automatic transmission (so no Solstices) and parts to rebuild them. Bulletin issued to remind dealerships to use the right parts for the right year and model.
07-03-08-003- Suspension Squeak Over Bumps in the Road
The early build 2007 model cold weather noise from the front stabilizer bar bushings, advising of new numbers. Talked about and posted on site alot starting last October but not a much now that the weather isn't cold.
1 - 2 of 2 Posts
Status
