Hi Guys,looking for help again. Last time that this happened I found a mouse stash in the air cleaner.I cleaned the MAP sensor as someone here advised and that solved the problem. Thinking I had the same problem this time I put in a new air filter and then found a broken fitting on the tube directly behind the MAP sensor. It connects a stainless braided hose into the top of the engine somewhere. Would this (hose not being connected) cause the turbo not to work? Would anyone have a part# for this tube ? Thanks again in advance for any help. Don
