1 - 6 of 6 Posts
So on Saturday when I was on the Niagara run, my CEL turned on. Scanned it with my Bluetooth scanner and it gave me P0420. Cleared it and it's now off, though I still want it checked since I'm under GMPP.
Any way I can turn the CEL back on so dealer will look at it? I did give them the code in the appointment...
Not if you cleared the code. Unless it goes off again.
P0420 is the low catalyst efficiency DTC. It usually trips when the "downstream" or post cat O2 sensor detects a problem with the catalytic convertor.
Light's back on, and took her in. Yep, it's the cat.
And hooray for a coolant leak too!
1 - 6 of 6 Posts
