Could you use it without the targa bar in the mean time, as a temporary solution?
It appears that your trunk lid is too high, as if it is not closed all of the way.Grrrr/
HH, sorry to see this doesn't fit perfect. Consider it a hiccup, and move forward. Is this something you can fix yourself?It would look great if it did actually fit.
View attachment 129951 View attachment 129952 View attachment 129953 View attachment 129954 View attachment 129955 View attachment 129956
I can but i had to remove the entire latch mechanism and chrome grommets on the trunk to be able to fasten the targa bar.Could you use it without the targa bar in the mean time, as a temporary solution?
If you look at the first pic i posted a close up of where the front of the targa bar meets the back of the top you can see that is precisely the issue.It appears that your trunk lid is too high, as if it is not closed all of the way.
I was gonna say the same. It seems that if you close the deck lid fully the targa bar might align with the top..?It appears that your trunk lid is too high, as if it is not closed all of the way.
Good suggestion. I went back to Gadget's zoomed in "won't fit" photos and was cracking my head trying to understand what now (after your comment) became clearer to me and seems to be the junction of a kind of squared front edge of the T bar onto a rounded trailing edge of the top.It looks as though the forward lower corner does not allow the the trunk to fully close. Is that the issue? Can the corner be radiused to allow it to lower down ? Otherwise it does look nice.
The solution to this is called Kappa Caps - DDM sells (had sold?) them. Attach them using 3m double sided tape...I can but i had to remove the entire latch mechanism and chrome grommets on the trunk to be able to fasten the targa bar.
So i have two big holes in the trunk where the grommets were until i can put that all back.
Wont fit with the chrome rounds on as the base of the targa bar sits on them half on half off..Is it possible the trunk bar portion was meant to sit on weather stripping and thus be slightly higher on the trunk decklid? Maybe when norm was fixing and fabbing he might have made them level but the original design spec was for the trunk spoiler to be slightly shorter and sit on rubber like a tradition car rear spoiler does.........
example from my daily driver New OEM Rear Right Passenger Side Spoiler Pad For 11-15 Genesis Coupe 872582M001 | eBay this rubber pad sits between the spoiler and trunk giving it roughly a eight of an inch rise, it's likely the original design would've had something similar instead of having composite sitting directly on the paint, would that roughly give the clearance your missing?
edited #2 how certain are you the chrome scuff guards/circles are removed for installation? it almost looks like the spoiler section wants to sit higher and tilt forward instead of being flush with the rear deck..... wish I could be there to assist with this![]()
Yes i have a set and may do that, or i may just re-install the soft top and put the hard top in storage until i can figure it out.The solution to this is called Kappa Caps - DDM sells (had sold?) them. Attach them using 3m double sided tape...
Decklid is slightly “back” as is. It shuts correctly against the soft top and has a slightly larger bodel panel gap on the front edge than the sides.Good suggestion. I went back to Gadget's zoomed in "won't fit" photos and was cracking my head trying to understand what now (after your comment) became clearer to me and seems to be the junction of a kind of squared front edge of the T bar onto a rounded trailing edge of the top.
I wonder if the car Norm used as a base was "longer" than Gadget's by a few mm? Or Gadget's deck lid is a tad forward and could be adjusted at the hinges?
This is likely the solution and was the conclusion i came to when i posted the photos.It looks as though the forward lower corner does not allow the the trunk to fully close. Is that the issue? Can the corner be radiused to allow it to lower down ? Otherwise it does look nice.
Thanks for the sentiment Chop. I am not a body guy and this one really needs somebdy very good. There is a mixture of bondo, steel and aluminum under the paint so it could get pretty tricky even for a savy body person.HH, sorry to see this doesn't fit perfect. Consider it a hiccup, and move forward. Is this something you can fix yourself?
He may also be able to explain how he test fitted it and what is different about what you are doing.I would apprise Norm of the results, after spending a lot of time with the top he might know of some adjustment that is not immediately obvious.
I will try to contact Norm of course.I would apprise Norm of the results, after spending a lot of time with the top he might know of some adjustment that is not immediately obvious.
