V8 Kappa's For Sale
77962 Views 322 Replies 56 Participants Last post by  rob the elder
Posted to Craigslist 4/26/14
LS7 650 horsepower pontiac solstice (No pics)
LS7 650 horsepower pontiac solstice - $40000 (Memphis, Michigan)
2007 Pontiac solstice. Ls7 power 650 hp. Tremec 6 speed, Cadillac ctsv rear end. All gauges a/c cruise control work. Averaged 21mpg cruising at 80 mph on the way to Frankenmuth, MI autofest. Parked on the street for the block party and had more interest than the 63 split window next to me. This car is top notch and is not a cobbled together piece. I put 5000 miles on it this summer and had no problems. This car is awesome. I need to sell to fund a new business venture. Cost to duplicate engine is 20+k, please no low ballers open to trades plus cash. Especially diesel trucks. 810-305-00fournine. No dealers/brokers. Car must be driven to be believed. If you drive you will buy. Call text or email.
301 - 320 of 323 Posts
2
If you read the description for the car it only states the backbone brace has been done. It does however state that there is a ford meatball in it so there could have been some work done to stiffen the chassis in the rear when that was put in. More then likely not because it sounds as tho the car still has an independent rear suspension and there would be no need to tie the 2 sides of the chassis together when doing that.
The TC and ESC do 2 things when they activate they step on the brakes for the wheel that is spinning faster then the rest of the wheels but it also cuts the throttle. If the tires actually connected right out of the hole the chassis on the Kappa would twist if the car has an engine in it that has a lot of bottom end torque. suspension mods does nothing for chassis stiffening. you will get a stiffer ride from suspension mods but that is not the stiffing that needs to be addressed.
This is to the extreme but you can see what I am talking about..
3 tires on the ground and one in the air.. only way that is going to happen is if the chassis is twisting because of the amount of torque.
Car Tire Vehicle Wheel Hood
Now here you see a stiffened chassis. both tires up an even amount
Tire Wheel Vehicle Car Hood
Those are examples and exaggerated ones at that.
that kind of twist occurs in the Kappas and is why the windshields have stress cracked as mine has done (and it is still cracked). Put a torque monster V8 in the car with tires that stick and if nothing breaks the amount of torsional forces that get transferred to the chassis is going to be far larger then what caused my windshield to crack. One way of avoiding that kind of stress is to not put wide tires on the car so they can spin and that stops the majority of the torque from being absorbed by the chassis.
See less See more
Reactions: 2
2
Found on FB Kappa Swap group. $25,000 Canadian = $19,049.035 US Dollars (as of 7/14/22).
Font Circle Number Rectangle Document
Car Land vehicle Vehicle Wheel Tire
See less See more
The chassis is well able to handle the added power. Yes, you can spin the tires, but also , the TC and Stability control functions and prevents wheel spin unless its turned off for each run cycle. I have zero issue putting power to the ground with my "Pizza Cutter" tires. :)
The conversion is well understood and there are tests and proven methods for addressing your points.
Many tracks require a driveshaft retention device that prevents it from going uncontrolled in the event of a failure.
What caused you to draw the conclusion that the only suspension mod was the backbone? The converted cars I have seen have the probeam or equivalent in addition to suspension mods.
Even without these mods, there are NA cars converted to LS motors that are doing just fine on the street.
Well right on the description is says
Chassis stiffener : DDM Backbone
You would hope that if they did more than that they would advertise it… but such is the land of custom swaps, lack of historical knowledge means the definition of YMMV.
I have seen very few cars that have a level of documented detail as yours does Rob.
Reactions: 1
Now there is a unique color. Interesting.
Just Listed today on BAT, 2006 Mallet #016 - this is a new car to me, 1st Canadian Mallet I have found.
Sold for $29,000.
Reactions: 1
That is an excellent price someone received! Only hassle is the conversion from Km to miles per hour.
Reactions: 1
I don't think that will be an issue, the car was originally sold in the US, and the odometer rears in Miles, I agree the buyer stole this one, but the fact it is now located in Canada, and no real driving video was posted didn't help the sale. That and the cracked windshield. I hope the new owner enjoys it!
Gauge Vehicle Measuring instrument Speedometer Gas
See less See more
Reactions: 1
No hassle. Just connect GM Tech device and change it
Reactions: 1
29k is giving it away. But lucky new owner
Depends on how bad it was wrecked. Doesn't really say, says damage to the right side on the Carfax.
Ahh I did not know it was damaged. Sorry.
On the other hand, the certified replacement value of my V8 is $100k so . . . .
2
A commenter made an observation that a LS4 would not work in this configuration and asked if it was a typo.
Edit to add, sellers response: Yes it will. The only real difference is starter mount and bellhousing. Custom billet starter mount and bellhousing and works absolutely perfect. Almost anything is possible with a little skill and cnc mill and help from some great friends.
Font Number Screenshot Document Parallel
Wheel Tire Car Vehicle Land vehicle
See less See more
something is a typo because the stock custer shouldn't be working either if the sky is a 2009. only the E67 ECM can work and that ECM will not work in a 2009 vehicle.... Not unless they took the entire wiring harness and all of the modules from a 2006 and put them into the car
$45,000
GM 430 HP V8 LS3 Crate Engine - Rated at 430 HP
GM 6L80E 6 Speed Automatic Transmission
Steering wheel mounted paddle shifters
B&B stainless steel axle back exhaust with dual exhaust tips
Carbon fiber wrapped RK sport dual exhaust rear valance
WERKSracing/DSS custom balanced carbon fiber driveshaft
WERKSracing polished stainless-steel Tru-ram exhaust manifolds
WERKSracing Custom motor and transmission mounts
WERKSracing Heavy Duty Big Aluminum Radiator
WERKSracing LS3 ECM and Werks custom wiring harness
Recaro Sportster GT suede seats with front to rear sliders
Custom cross stitch pattern suede center console and door panels
Pontiac Solstice V8 Conversion Options - Air Conditioning
BC racing BR Series Coilovers
Wilwood upgraded big brake kit
Aluminum tunnel brace
Werks complete detail
Many other small details!!!
59,500 miles
See less See more
What vin #??
2
See less See more
HAHAHAH Great car and it has some of the same mods as Punisher. I really hope he gets ore than $60 for it. He probably has closer to $70 k in the car. But I wish him best luck.
Reactions: 1
2
VIN 792 $55,000
See less See more
Reactions: 1
