There has been some discussion pertaining to OEM 2009 and prior lifters being suseptable to failure in applications where big HP numbers are developed. The school of thought appears to be that replacing with 2010 or later Cobolt SS lifters, will significantly reduce the possibility of failure. From what I can work out all 2010 and later LFN / Ecotec applications are using these updated lifters.
Questions:
1. Why are they different.
2. What exactly has failed
3. Has anyone ACTUALLY had a failure and if so, what happened
4. Is there an aftermarket solution.
I am upgrading my valve springs to Supertech dual's and this would be a perfect time to upgrade the lifters -- if it is really required.
producing big HP numbers. The school of thougfht is to replace with OEM lifters from 2010 and later Cobolt SS Ecotec's.
Questions:
