1 - 2 of 2 Posts
I need some help please.
I am about to swap out my valve springs and cam followers. Need to know if there is a special GM tool required to hold the timing chain in place? We are doing this without removing the head and are scratching our heads on how to ensure the chain does not drop or slip a tooth.
Any info, including OEM technical guidelines would be greatly appreciated.
Oh, and does GM make a specific valve spring compressor for the LNF.
Thanks.
I know there are a couple of how-to threads on water pump replacement indicating specifically what tool to purchase and from where. Just hit the "search" icon under water pump replacement. Another resource for the tool would be the DDMWorks waterpump replacement video. Unfortunately, I wouldn't know about the valve spring compressor. Good luck.
1 - 2 of 2 Posts
