41 - 60 of 68 Posts
There are 2 RPO codes that I have located that may be for those labels UTT and VLT
FWIW . . . I checked Compnine RPO Lookup and they do not list those RPO for any Kappa in any model year
Discussion Starter #42
@Steveorama
It's all about the person you get and if you can persuade them to take the time to do it.
@agent008
If you can prove that the stickers are an option and that your vehicle did not have that option when it was built they may decide to use the certificate in the drivers door jamb as a way to verify the VIN.
All you have to do is to get me the list of RPO's from your car and I will have them all decoded in about 2 seconds. I am also going to need an RPO list from someone that has the stickers so we can compare the output from the 2 and see if there is something that stands out.
I'll get you a pic of my glovebox sticker once I get home from work, it's going to be a long day to compensate for tomorrow's holiday. Thanks!
Discussion Starter #43
I’ve heard people in Brazil are really friendly, but I can’t imagine their DMV’s are any more accommodating than here in the states. I can’t even imagine the reaction I would get from our DMV here if I asked them to call anyone for anything. Ha
I live in a samll town, the officer at our DMV is an acquaintance, in fact I bought the car with money I received by selling my old house to her son. She is nice but always follows the "cold letter of the law" down to the commas and periods. Difficult to convince her, but everyone here is being most helpful. Once I solve this I will let all the folks here know.
2008 Pontiac Solstice GXP
oOooO It worked! and it only took a tad over an hour to get a response.
If you e-mail this address
[email protected]
and request the build sheet for your car giving them your full name and also the vin number of the vehicle.
This is what I sent
I would like to get a build sheet for my 2008 Pontiac Solstice GXP please.
1G2MG35X48Y115884
Thanks again
Kevin Schlosser
and this was their response
Hi Kevin,
Vehicles are equipped with a passenger airbag suppression system (PPS) that is designed to determine whether the passenger seat is occupied by a child and whether the front passenger airbag should be suppressed during a crash. The PPS system
uses a flexible sensor mat inside the passenger seat. Occupant pressure on the seat in the same location can, over time, bend and damage the sensor’s printed conductor. In severe cases, this damage can cause an open circuit in the sensor. While the
sensor circuit is open, the PPS module will indicate to the vehicle’s sensing and diagnostic module (SDM) that a fault exists in the PPS system, and the SDM will—by default—suppress the front passenger airbag during a crash. If an active fault exists in the PPS system and a crash occurs, the SDM will not deploy the front passenger airbag. If an adult is occupying the passenger seat, the
suppression of the front passenger airbag could increase the risk of injury to the passenger. You should schedule an appointment for this recall as soon as possible.
Additionally, I have provided the build sheet for your vehicle. If you have any questions, please let us know
Best,
Rachel A.
GM Customer Care
and attached is the build sheet.
I would send that e-mail a message outlining your conundrum and see if they are able to provide a solution for you. Give them your VIN and tell them what dealership exported the vehicle and where the vehicle got imported to. Explain to them that where you are the DMV verifies the VIN by using the dash VIN and also an anti theft label on the passenger door. Tell them that you have no such label on the door, fenders, hood or trunk and that you believe that it may have been an option but you are not sure. Tell them that they will not allow you to register the vehicle without those stickers and that replacement stickers can be mailed to the DMV by GM. You just need to know who to contact in order to get this done.
Also request a build sheet for your vehicle while you are at it.
Reactions: agent008
..... I am also going to need an RPO list from someone that has the stickers so we can compare the output from the 2 and see if there is something that stands out.
I must always get the wrong person then. lol.
Here is my RPO list FWIW as I have the stickers all over the car.
RPO CODES
AL0 AU0 AU3 AZ5 A31 A50 B32 B70 C60 D48 D52 E2C FE3 FE9 GTA GT4 G80 IP2 JF5 JL9 KG9 K34 LNF MX0 M82 NT7 N34 PD5 QSL ROO R6H R7Y R9N R9Z SLL T96 UE1 UK3 UQ3 US6 US9 U2K VG8 VK3 V73 WIL 1SZ 31I 312 60T 72U
I know what all of these represent except for; ROO R6H R7Y R9N R9Z. All I have ever found is that they are control numbers.
RPO CODES
Code:
AL0: SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR
AU0: LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM)
AU0: LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYSTEM)(USED WITH TROFEO SPORT COUPE WL3)
AU0: LOCK CONTROL,REMOTE ENTRY(KEYLESS ENTRY SYS)(INCL REM HATCH CTL)
AU3: LOCK,SIDE DOOR,ELECTRIC
AU3: LOCK,SIDE DOOR,ELECTRIC(EXPORT,CANADA)
AZ5: SEAT FRT BUCKET, HIGH BACK, PASS & DRIVER RECL, 4 WAY ADJ
AZ5: COVERING HEADLINER CONVERTIBLE TOP TRIM
A31: WINDOW,ELECTRIC OPERATED,SIDE
A31: WINDOW,POWER OPERATED,ALL DOORS
A31: 2011 OEM ENGINE PHYSICAL ID A31 & PRODUCTION NUMBER 94672450
A50: SEAT,FRT BUCKET,CUSTOM
B32: COVERING,FLOOR MATS,FRONT AUXILIARY
B70: PLATE DOOR SILL COVER
C60: AIR CONDITIONER,FRONT,MANUAL CONTROLS
D48: MIRROR O/S LH & RH, REMOTE CONTROL, ELECTRIC, COLOR
D52: SPOILER,REAR END SPORT
D52: SPOILER,REAR END SPORT(EXPORT,CANADA)
E2C: ORDER TO DELIVERY EXPEDITE TO CUSTOMER
FE3: SUSPENSION SYSTEM,SPORT
FE3: SUSPENSION SYSTEM,SPORT(USED WITH GT Z21,CORSICA LTZ Z54,CONV PKG Z08)
FE3: SUSPENSION SYSTEM,SPORT,MEX DOM USE ONLY
FE3: SUSPENSION SYSTEM(SPECIAL)(LESS STABILIZER SHAFT)(USED WITH TROFEO SPORT COUPE WL3)
FE9: FEDERAL EMISSION CERTIFICATION
GTA: MODEL CONVERSION TURBO GT
GT4: AXLE,REAR,3.73 RATIO
G80: AXLE,REAR,POSITRACTION,LIMITED SLIP
IP2: TRIM,INTERIOR DESIGN
JF5: PEDALS SPORTY, ALLOY
JL9: BRAKE SYSTEM,POWER,FRONT AND REAR DISC,ANTILOCK
KG9: GENERATOR,140 AMPERE
K34: CRUISE CONTROL,AUTOMATIC,ELECTRONIC
LNF: ENGINE GAS, 4 CYL, 2.0L, DI, ALUM, DOHC, TURBO, GM
MX0: TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)
M82: TRANSMISSION AUTO 5 SPD, HMD, 5L40-E, ELECTRONIC
NT7: EMISSION SYSTEM FEDERAL, TIER 2
N34: STEERING WHEEL,PLASTIC WOODGRAIN
N34: STEERING WHEEL LEATHER, 3 SPOKES
PD5: WHEEL 18 X 8, ALUMINUM, CHROMED
QSL: TIRE ALL P245/45R18-96W BW TL HW4
ROO: PROCESSING BARS INTERNAL CONTROL SLM - STOCK ORDERS
R6H: SDS CHARGE
R7Y: COMMUNICATIONS PLUS
R9N: PROCESSING CODE -SEAT
R9Z: POMS EXPEDITE-SOLD ORDERS
SLL: SOLD ORDERS
T96: LAMP,FRONT FOG
T96: LAMP,FRONT FOG(USED WITH TOURING YP6)
T96: LAMP,FRONT FOG(USED WITH BERETTA GTZ Z04)
T96: LAMP,FRONT FOG(EXPORT)
T96: LAMP,FRONT FOG(USED WITH TOURING YP5)
T96: LAMP,FRONT FOG(USED WITH TROFEO WL3)
UE1: COMMUNICATION SYSTEM VEHICLE, G.P.S. 1
UK3: CONTROL STEERING WHEEL,ACCESSORY
UQ3: SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO
US6: ANTENNA,FIXED(PAINTED)
US6: ANTENNA,FIXED(PAINTED)(RH REAR QUARTER PANEL MOUNTED)
US6: SPEAKER,FRONT SIDE DOOR
US9: RADIO AM/FM STEREO, SEEK/SCAN, RDS, MULTIPLE COMPACT DISC, AUTO TONE CONTROL, CLOCK, ETR, MP3
U2K: DIGITAL AUDIO SYSTEM S-BAND
VG8: LABEL,NOTICE TO BUYER
VK3: LICENSE PLATE,FRONT MOUNTING PACKAGE
V73: VEHICLE STATEMENT - US/CANADA
WIL: PLANT CODE- WILMINGTON,DE.(CPC)
1SZ: PACKAGE OPTIONAXLE,FULL FLOATING
31I: INTERIOR TRIM LT CASHMERE (04)
312: TRIM COMBINATION LEATHER, LT CASHMERE (2) (04)
60T: TOP COLOR CONVERTIBLE, CLOTH, NEUTRAL
72U: EXTERIOR COLOR,PRIMARY,MEDIUM GARNET RED METALLIC
72U: EXTERIOR COLOR,PRIMARY,STANDARD RED
72U: PRIMARY COLOR EXTERIOR, BLUESTONE MET
Code:
R6H: SDS CHARGE
SLL: SOLD ORDERS
T96: LAMP,FRONT FOG
Thanks, that matches most of what I had. Interesting on the codes I had as control codes. I'm still not seeing anything that would indicate the VIN stickers though. Does everybody else have these? I looked at my 2015 Silverado and it doesn't seem to have any.
the VG8 RPO is suspicious, I have an 08 GXP without the stickers and I do not have the VG8 RPO, there are several other RPO's that I do not have but nothing that is a "label"
Discussion Starter #50
Good afternoon / evening to all, hope you have had a nice Easter holiday.
My glovebox sticker lists:
AU0 AU3 A31 A50 B32 C60 D48 FE2 FE9 GW1 IP2
JL9 KG7 K34 LE5 MA5 MM5 NT9 N34 N87 PCQ QFX
R6P R8K R9N SLM T96 UK3 UQ3 US6 US9 U2K U68
VY7 V73 WIL ZQ2 ZQ3 1SA1ISZ 19I 19T 192 74U
BC/CC U 9260 192 19T
So, no VG8 in my build sheet... could be the anti-theft sticker RPO.
Here are some pics, from the spots where the VIN/anti-theft stickers would be (as per @Steveorama's car).
Trunk:
112049
Trunk - Drivers side 1:
112050
Trunk - Drivers side 2
112051
Trunk - Passenger side 1:
112052
Trunk - Drivers side 2:
112053
Passenger Fender:
112054
So, really couldn't find any stickers whatsoever, and no VG8 in my glovebox sticker.
Thanks everyone for the willingness to help.
I do not have the VG8 RPO either and I have no stickers. If there is someone that could confirm this by letting us know if they have the VG8 RPO and if they have the stickers or not.
My '07 NA Sky does not have VG8, and has no stickers.
My '08 RL Sky does have VG8 and does have stickers.
Discussion Starter #54
I just googled "VG8 RPO GM" and struck a 412-page long PDF file where VG8 is mentioned. The result is "VG8 LABEL, NOTICE TO BUYER".
112061
Maybe somewhat vague (even misleading? as "notice to buyer" could be airbag/PPS warning label, emisions label, tyre pressure label etyc.) but we now know for sure VG8 is a code for labels of some sort.
EDIT: I decided to search for the word 'label' on that PDF. I got
112062
Googled Thatcham, seems to be an UK insurer so maybe VLT would be the anti-theft label RPO? Makes sense an insurance company would demand those.
The VG8 RPO I can now confirm is the anti theft label. There are 2 people that have the RPO and the stickers, and 3 people without the RPO and no stickers. I am 99% sure the VG8 was an option that your vehicle was not equipped with. You might be able to bring this to the attention of the DMV and they might be able to come up with some other way of verifying the VIN. This shows that the sticker has not been removed or painted over. It was never there to begin with.
The VLT RPO is not used on the Solstices.
I am not sure if they would understand this or in what manner you would have to prove the what the RPO is . GM having the description for the RPO as "Label, Notice to Buyer" isn't going to help matters. GM does however use the same RPO for different vehicles and they can mean different things. So you might be able to get something from GM Brazil for the VG8 RPO for the Solstice that has a different description. If you get it printed out on letter head and also a description of where the RPO code list is in the Solstice also on letterhead they would be able to confirm that the stickers were an option and that your vehicle does not have that option.
@agent008
here is your RPO's decoded
Code:
FE2: SUSPENSION SYSTEM,RIDE AND HANDLING
GW1: AXLE REAR 3.91 RATIO
KG7: GENERATOR 125 AMP
LE5: ENGINE GAS, 4 CYL, 2.4L, MFI, ALUM, DOHC, HO, ECOTEC
MA5: TRANSMISSION MAN 5 SPD, AISIN, 82 MM, 3.753 1ST, 0.729 5TH
MM5: TRANSMISSION,MANUAL 5-SPEED PROVISIONS(MERCHANDISING OPTION)
NT9: EMISSION SYSTEM FEDERAL, TIER 2 PHASE-OUT
N87: WHEEL 18 X 8, ALUMINUM
PCQ: PREMIUM PACKAGE
QFX: TIRE ALL P245/45R18-96V BW R/PE ST TL AL3
R6P: OL SALES ITEM NO. 15
R8K: OL SALES ITEM NO. 61
SLM: STOCK ORDER, PROCESSING CODE
T96: LAMP,FRONT FOG
US6: ANTENNA,FIXED(RH REAR QUARTER PANEL MOUNTED)
U68: DISPLAY,DRIVER INFORMATION CENTER
VY7: KNOB,TRANSMISSION CONTROL LEVER,LEATHER
ZQ2: DRIVER CONVENIENCE PACKAGE
ZQ3: DRIVER CONVENIENCE PACKAGE II(MERCHANDISING OPTION)
1SA: PACKAGE-OPTION 01
ISZ: DISCOUNT OPTION PACKAGE (VALUE GROUP)
19I: INTERIOR TRIM,EBONY
192: TRIM COMBINATION,BLACK/EBONY LEATHER
74U: EXTERIOR COLOR,PRIMARY,VICTORY RED
19T: TOP COLOR CONVERTIBLE, CLOTH, EBONY
Reactions: agent008
Keep in mind that RPO codes are not absolute, as the same code can mean different things in different years.
The VLT code does not appear in the list for my '08 that has the stickers, so I think not.
Reactions: agent008
@agent008
I contacted GM about your issue. This is the response I got back from them.
Hi Kevin,
Unfortunately, our team does not have that information. We encourage you to use the Heritage Center, as well as your selling dealership for additional insight. They will be in the best position to further assist you with those questions.
Best,
Rachel A.
GM Customer Care
Here is the e-mail address for the heritage center.
[email protected]
Reactions: agent008
Discussion Starter #60
Good news. I got the car titled in my name and instaalled the new paltes. I have, however, until next year to get the stickers. So I will have to keep searching.
@kgschlosser , I appreciate you reaching out GM Customer Service with my story. I will prepare a detailed email and send it to Heritage Center.
My heartfelt thanks to all that took their time to help somebody you don't know, and who has just come up on this forum recently, solve his problem.
41 - 60 of 68 Posts
