1 - 5 of 5 Posts
topdown2006 said:
Can I track the build of my Solstice on line? with the VOM
VOMS is a GM system that can only be accessed through a GM dedicated server is each dealership.
So there is no way a comsuner can access it.
topdown2006 said:
:willy: Can I track the build of my Solstice on line? with the VOM
Unfortunately, no. Only your dealer can do that for you. Most dealers are willing to check every week or two. Might take a little convincing on your part, or a little research on which people at the dealership actually have the knowledge on how to do this.
Good luck! :)
Oldegoat said:
Can someone explain the "Order Type" field? Mine has "Order Type: TRE-Retail Stock".
The "Order Type" field is just that, the type of order that it is. Depending on where you look, it can be code or words. Your example uses both.
"TRE" is used for retail orders for dealership stock. This means the order is retail, not for fleet and for stock not a sold customer.
Retail Stock (TRE) and Retail Sold (SRE) are the two most common "Order Types"
1 - 5 of 5 Posts
