1 - 6 of 6 Posts
Anyone have an old/spare oil vapor vent pipe? Possibly one that they've replaced due to a stuck/busted check valve at the airbox?
The part I mean is the braided piece marked with the red line in this photo. I actually just need the pipe itself (and end fittings) but will happily take the check valve (blue) too if still attached.
Wanting a spare to try out a mod. If you can help, please PM me. Thanks!
You're replacing something that may not even be bad? You should try blowing and sucking on the end of the line (with suitable precautions of course - don't want a mouthful of oil) and see if the valve works or not. Only then can you tell if you need to clean, replace or leave alone.
I have my old one, however you are a long distance from Arkansas :brentil:
I should have one. I will check
OK thank you very much for all the offers. Received an old vent pipe from a member. This thread is done!
More to come, maybe later, if my proposal works.
1 - 6 of 6 Posts
