1 - 4 of 4 Posts
Does our cars have a low washer fluid warning light? Im planning on adding methanol injection kit from ddm and was going to just run from washer fluid reservoir but would like it to have a warning light. If we don't have a warning light has anyone added and aftermarket one to our cars or do you all who have this kit just check every fill up?
as far as I know, there is no warning light for washer fluid...
I think there's rules about posting links from non-vendors but if you google "methanol float switch" you'll find things that you could use. You could also probably contact Dave at DDM and he will probably either sell you something or tell you what he recommends.
I have a custom made tank that holds almost 2 gallons that I just check from time to time. When the system is set up correctly, and if you don't really hammer your car, 2 gallons will last a pretty long time. I think the stock washer tank is about a gallon and I would think that would easily last at least a tank full of gas, again unless you are really driving your car hard.
1 - 4 of 4 Posts
