1 - 2 of 2 Posts
For those of you who have the AEM Water/Methanol Injection kit and a DDMWorks Stage III SuperCharger, Please give me some install advise.
1. Where is the best place to install the injectors. My throttle body and supercharger seem to get hot so would it make sense to place one right before the throttle body and another one after the MAF sensor just before the air enters into the engine? There are no supercharger specific install instructions with the kit.
2. What size injector(s) do you use and why? I was thinking the medium spray for the throttle body and the small one after the MAP sensor? (After the install, Dave at DDMWorks will HP tune the car. I am really looking forward to that).
3. How did you tap into the existing washer fluid reservoir with the parts off the AEM bottle?
4. Where did you mount the pump and controller?
Thank you for your advise.
John G
aka, Rx4theSol
When DDM did the meth install on my GXP last month that install the pump on the underneath of the car on the firewall. There is a perfect spot for it to fit. I can't take a pic as I just had gallbladder surgery.
1 - 2 of 2 Posts
