I just topped off my coolant 2 days ago, weird? Any thing I could do, or just ignore it? Any way to reset it? It goes off from time to time then away…
These cars are known for water pump failures and that’s usually where it leaks from (and it starts as a really slow leak that only blinks this light at you occasionally). I currently am replacing my WP in my parent’s garage.I just topped off my coolant 2 days ago, weird? Any thing I could do, or just ignore it? Any way to reset it? It goes off from time to time then away…
This is what I needed this morning. I just topped if off 3 days ago. Thanks showtime, appreciate you as always!My coolant sensor is bad and is on and off frequently. I'm waiting until it really annoys me before I change it.
I'm just leaving that one alone...Now I am getting urges.
yes - it happens - this was my problem on one of my cars.There are also reports of the connector to the coolant level sensor on the "bottle" being corroded or the level sensor itself failing. I'd recommend disconnecting and reconnecting the plug several times to clean the contacts and see if that clears it up.
