1 - 6 of 6 Posts
Hi Guys,
i just noticed that one of "behind seats" cover doesn't open/close and roof cant get down. After quick inspection I noticed there is a red plastic and its broken!
I went through catalog and I couldn't find it, can you tell me which one is it? Where can I buy it?
images attached
Basically the metal piece doesn't hold inside and pops out all the time while putting roof on top.
GM parts
Discussion Starter #2 (Edited)
Is it guys this part 16 ? called spring?
37$ ?
Is there way to buy just the small plastic part instead of whole thing? I dont even know if this part has the plastic holder.
108548
ok I found the plastic things here:
108549
37$ ?
[/URL]
37$ ?
That red part can be found at just about any auto parts store. AutoZone, Advance auto, etc..
OK, you found the "clips", now, bend that cable end so that it looks like an "L", two straight pieces connected at a 90 degree angle. And then adjust your cable so that it isn't pulling hard against the clip. There are instructions somewhere on this forum.
:thumbs:
The plastic clips ( red or blue-ish ) have been known to break. Buy the replacement clips. The color of the clip does not matter.
1 - 6 of 6 Posts
