1 - 10 of 10 Posts
Hello all-
No replies to my thread, so I'll rephrase the question. I know someone on this site has the answer. I've read many posts on this subject,with people discussing spacers,etc. I'm looking for a bolt on setup with no issues.
I'm interested in the Enkei Ammodo or Emk3's (18" x8 5/110 40mm offset.
Does anyone know if they will clear the calipers?
I'm running 245/45/18 Hankook v12's. Any interference with the fender wells?
And lastly, do the Enkei's have the proper centerbore dia? Which design do you guys think looks nicer on my Sly NA? I was looking for the Gravana look in silver.
Thanks in advance and have a great holiday.
All the best,
John
P. S Rob, quit painting that car and answer my question!
Chickenwire,when you're done shoveling snow in Texas,let me know what you think..Oh, we have no snow here in sunny northern NY ..haha (yet)
With a 40mm offset they'll stick out 15mm more than stock rims, and will have more clearance for calipers. Take a ruler and add 15mm to the tire and see how close it gets to the fender wells and you'll have an idea if they'll fit right.
No idea on the center bore diameter, email enkei and find out and if its not 65.1mm you'll have to get hubcentric rings to fit on the hub and enkei rims.
Thanks Shabby for the input.good to know that the calipers will clear. I'll check the extra 15mm and contact Enkei regarding bore diameter. If needed ,where do I get hubcentric rings?
All the best,
John
I assume they will clear the calipers because the offset is 15mm farther compared to stock rims, how the actual spokes look and if they will clear 100% i have no idea but 99.9% they will clear.
Enkei should be able to include those rings if you specify for what car they're for, otherwise you can get them on ebay.
Discussion Starter · #5 ·
Thanks again Shabby for your time. I'll contact Enkei.
All the best,
John
Did you check the clearance? I think they might fit my lowered car. I'm considering buying a set of those as there's a guy that sells them very cheap.
I have those wheels on my car - no problems. Great wheels. Sorry I missed your question earlier.
1 - 10 of 10 Posts
