still though can't you remove the factory one if you have it and install it in it's place? if not then what about on the rear pilar between the tulip panels. you'd have easy access with the waterfall removed. If you do end up mounting it where Bob has his, I'd suggest painting the window trim black. it's go real good with the yellow and would make it much less noticeable.
