1 - 3 of 3 Posts
Would these tires work? In 215/55R17? What would the resale value be if I only used them for the rest of the winter (2 months)? How would it affect performance? Thanks
Also do I need all 4 or 2?
You would be better off running a 225 /55/17 but that size should work ,4 tires are much better then 2 especially on a light , short wheelbase car like a Solstice a wider tire tends to plow through the snow that's why a narrower tire is a better choice .Tough call on the resale because you have to factor in the rims which fit a limited amount of cars but if you live in the snow belt there will always be a demand for these types of tire I'm assuming you are buying a new set .The car should handle much better especially in the snow as the OEM tires are more performance orientated .
1 - 3 of 3 Posts
