1 - 5 of 5 Posts
Looking to purchase a catless downpipe for my 07 Saturn Sky Redline!
Let me know what you have and how much you'd like!
Thank You!
You are looking for a test pipe. If you just do that it will throw a check engine light for O2 sensor. Just buy a high flow cat or take your cat off and gut it out. Would be easier.
Wouldn't i be better off going up to a 3"? I assume our stock downpipe is only 2.5"
Unless you use a larger turbo and or tune, the size increase isn't going to get you anything.
Get a high flow CAT and then tune.
You are correct. If it's a catless DP you are looking for, then that is what you should be looking for. Just make sure you do your homework and research regarding Tunes,CELs , etc.,etc.
Most common are Solo,Werks, others I believe were\are available at one point.
The Home of WERKSracing products!
I have a Solo catless, and I love it.
Bert
1 - 5 of 5 Posts
