Anyone make GLASS Solstice lenses?Looking to replace the sun damaged plastic headlight lenses. Don't know if it is possible to just buy headlight lenses or if I need to buy the whole headlight assembly.
Good info.Having been through this with my second set (HID retrofits), I can tell you they'll polish up almost like new (I recommend the 3M kit). BUT!
If they are bad now, you may find visible micro cracks in the lenses that are impossible to remove. Also, the polishing will not last very long. Once the factory protective coat has gone, there's nothing left to keep them protected and stop them yellowing again. Some folks suggest painting them with automotive clear-coat (once polished clean) to protect them again. I have no experience, so cannot comment.
Still, cheaper to try all that than replace the lenses, and if nothing else it will buy you time to find good used ones
3M kit is available at Wallymart cheap (or: 3M 39008 Headlight Lens Restoration System : Amazon.com : Automotive)
While I was looking for the above link, I also found that 3M now have a new kit with protectant: Amazon.com: 3M 39045 Headlight Renewal Kit with Protectant: Automotive
There are a lot of posts on this I just did this today : Remove the headlight assembly from the car 4 screws /unplug the light/ remove the rubber gasket on the light plug you can pry it off with a small screwdriver be gentle /heat oven to 200 degrees /pop in the assembly for 10 minutes /start at one end I started with the front and gently pry up the lens / as you go along carefully take a razor knife and score the sealant and make sure that you dislodge the lens from the tabs on the base / when you are ready to put it back together just guide the lens onto the base lining up the tabs I used a very thin bead of Permatex black silicone sealent in the light base channel just to be sure I did not have any moisture issues /squeeze everything together and pop it back into the oven for 10 minutes / remove it and squeeze it back together again making sure that the lens sits properly in the base .The reason to reheat it is it softens up the sealant and the lens sits in the channel properly . DoneI just tried some headlight lens restorer on my 2009 Solstice.
Some of the discoloration came out, but could there also be discoloration on the INSIDE of the plastic lens?
If so, can I (or someone who actually knows what they are doing) remove the plastic lens from the headlight assembly to get to the inside of the lens?
