1 - 7 of 7 Posts
Looking for GXP FE3 swaybars or any ZOK bars (with corresponding brackets & insulators)
Would also consider spring and/or shock combinations for the above.
I have the stock front and rear GXP sway bars available and 4 stock GXP coilover shocks with springs. Located in Southern California. I believe the stock GXP sway bars are called FE3. Forgive me if I'm mistaken. Taken off low mile Solstice GXP.
Thanks Alan! Check your DMs. I also contacted you about the OZ wheels you have listed. I don't necessarily need all of the shocks and springs but if they're in good shape I may take them as race spares.
I bought Z0K front and rear sway bars from DDM, do they not have them anymore?
PAW sway bars are MUCH stiffer and have 3 adjustments to change tension.
GXP's did not come with adjustable "coilovers".
I ordered my BC Racing BR Coilovers from DDM.
Thanks for that. I was looking for the source of these 'adjustable' sway bars
PAW also shows GXP ZOK bars which I haven't found anywhere else. DDM shows bushings for sway bars but I can't seem to find the actual bars themselves on their site.
I have the Performance Auto Werks set on my car and am very pleased with them I have them set at the middle setting which is a bit stiffer than ZOK bars .No matter what bars you buy invest in polyurethane bushings with grease fittings and use synthetic grease .
1 - 7 of 7 Posts
