I bougth mobile 1 lasy night but just noticed it is 10w-30, old habit I guess. I see our cars call for 5w-30. is there a big difference? should I take mine back and get new?
I'll be using Castrol 5W30, I'd use synthetic if I were going to have a turbo, but I'm not likely, so I'll stick with my favorite - casterol.Excelsior said:As for what oil is best, thtat is a loaded question that will get numerous correct answers.
I believe that the number in front is the winter weight of the oil ... that is for when it is cold out side. I see you are in NC so if you were going to run the oil this summer then you could in theory get away with itSolsticeSteve said:I bougth mobile 1 lasy night but just noticed it is 10w-30, old habit I guess. I see our cars call for 5w-30. is there a big difference? should I take mine back and get new?
I would agree,but in the future I,d run what is specified.5W30JustMike said:I believe that the number in front is the winter weight of the oil ... that is for when it is cold out side. I see you are in NC so if you were going to run the oil this summer then you could in theory get away with it![]()
achieftain said:...Granted it would be rare to have an engine failure just because you went 7,000 miles between oil changes instead of 3,500, if you did go extended oil changes and had a problem your warranty coverage could be in jeopardy.
:agree: :yesnod:Temple said:Amsoil is one of the best if not the best out there.
so what if you use the GM Oil Life Indicator in the DIC.....you could go 7-10K miles between oil changes depending on driving habits...the manual makes no recommendations I do beleive as to oil change intervals..mileage wise..but rather refers to the GMOL for when to change your oil.......we use mobil 1 sythn in our sol..and generally change it every 6-7K.....with the GMOL usually indicating 30-40% remaining......achieftain said:I grew up on the notion that Pennsylvania Grade Crude was the best due to the type of dinosaurs that lioved and died here. BUT, even Quaker Stae and Pennzoil (now one company) moved to Texas long ago. I still use Pennzoil in most of my cars and for my offroad vehicles I use Valvoline. I stick with regular oils and do not use synthetic unless the mfg calls for it specifically (as do some ATV mfgs). I have nothing personal against synthetics or blends but keep in mind that using Mobil1 or Syntec when not specified does not exempt you from changing the oil at specified intervals to protect not only the engine but your warranty. Granted it would be rare to have an engine failure just because you went 7,000 miles between oil changes instead of 3,500, if you did go extended oil changes and had a problem your warranty coverage could be in jeopardy.
:agree: very nice dealerChief Jay said:The oil I'm using is whatever the dealer is putting in it. Believe this or not, the dealer sent me a coupon book that gives me free oil changes for the first 36,000 miles every 3,000 miles. I'd be very stupid not to take advantage of it.
The OLM is algorithmic based and calibrated for conventional oil and typically will see 10kish miles (for conventional oil) dependent upon # of starts, # of RPMs, etc... Years of research by GM and independent oil lab analysis going back perhaps 15 years verify this.The important distinction here isn't brand or base stock but API rating and SAE viscosity. Both are requirements for warranty as well.Fortimir said:*shrugs*
I use Mobil 1 Synthetic, and my Oil Life Monitor is right on track to ask me to change my oil at 10,000 miles. I'll probably change when it says 25% remaining.
The W does NOT stand for winter!iamsly said:You will be fine in the summer with 10w30. The W stands for winter weight. since it isn't winter anymore the 5 or the 10 doesn't mean anything. In the future you will want to stick with a 5w30 but leaving the 10w30 in for the summer is not going to hurt anything. I'm a manager at an auto parts store and my husband is a technician at a shop we've been in these careers for 8 yrs plus together so belive me when I tell you you will be fine.
