What do you think of the Alpine SWS-1023D subwoofer? Do you think this could fit in out Monsoon sound system box?
I Verified and made sure it was like the stock woofer (double voice coils 2 ohm + 2ohm)
The top mount depth is 4 1/4! is this to large? Maybe I can add a little ring spacer for it to fit?
I just got my car back from the dealer for some sound system work and it turns out none of my problems are covered because the P/O did a hack job on the audio system. I must absolutely replace all speakers and the subwoofer. The subwoofer box is already cut out for a 10" sub, therefore going back to a 8 inch is impossible unless I change the box. The factory monsoon amp is still present.
I've also decided to match the amp up to the following speakers:
Rear: Polk Audio db351 3.5" 4ohm
Front: JBL GTO607C 6.5 2ohm
I really would like to keep the factory amp and head unit. I'm not after killer sound, just good sound and I can’t currently afford an amp.
any advice or opinions are appreciated!
