I have recently been getting cars with 100,000 and better mileage and in the process of replacing timing chains water pumps and turbo I have noticed a some what troubling condition. This past weekend I started working on a GXP with 99,000 miles the previous owner said his shop diagnosed it with a timing chain problem and after removing the front plate that was confirmed. What I was not expecting was the near catastrophic failure of the crank shaft end. If the pulley had cleared the key it would have spun on the end of the crank shaft and severe damage would have occurred. I was somewhat surprised when my battery powered impact knocked the crank pulley bolt of with relative ease. What I was not expecting was to find the main pulley was pulled out to the point that just a fraction of the woodruff key was still in contact with the pulley (see images). If that pulley had cleared the key the pulley would have damaged the crankshaft end and at the least the engine would have had to been dissembled to either repair that damage or more likely install a new crank. This is the 3rd engine I have gotten into with high miles and found that the crank shaft bolt was not tight to at least the spec required. I have also found that even though the vehicle was still running fine one or more of the chain guides have failed resulting in bolt heads being worn off by the main timing chain. All of these events have happened in the 2.0 engines although I haven’t torn into as many 2.4 engines to have an opinion on them. I believe the spec for the crank pulley bolt is 74 foot pounds plus and additional 75 degrees of rotation. I will begin to check the torque on the future cars I get, 2.0 and 2.4 engines, to see if this is a minor occurrence or something that may require more attention.
I point all of this out in hopes it will benefit others and I am not suggesting that this is a major problem. I would consider it a maintenance issue that comes with higher mileage vehicles and could prevent a future problem.
