My turn for Street Edition - Guide How To
5.5K views 17 replies 9 participants last post by  blackbirdracing
#1 ·
There are a number of these guides on the forums. I blacked out my headlights today in 35 degree weather in my garage for the "Street Edition" look, after Rob informed me that I just needed to use oven cleaner on the chrome and that I wouldn't need to paint anything.
Remove the headlight bulbs and use a #30 Torx to remove the 4 screws per headlight. Next I mounted my heat gun in my vise (so it was stationary) and turned it on as hot as it would go. I hand spun the headlights around letting the heat gun shoot right onto the seam. For me it was easier to start "prying" from the back of the headlight instead of the front due to the mounting tabs placement. Once the seam was hot I use a screw driver to start the pry and then simply ripped it apart with brute force (and more heating as I was prying) using the mounting tabs as leverage. It took quite awhile for me to get it apart, it's possible that the oven trick would have been faster but....that's not what I did. Once you have the housing in two pieces you unscrew the 4 phillips screws that attach the chrome inner from the clear outer. Now the headlight will be in 3 pieces. I repeated the prior steps on the other headlight. I then put both chrome inner pieces that I wanted to black out on a cardboard box in my garage and liberally covered both surfaces with Heavy Duty Easy Off Oven Cleaner (not the fume free variety). Others said they left it on for 5 minutes then wiped it off. I tried wiping after 5 min and it took too much effort to remove the chrome so I let it sit for 15 min while I drove to Harbor Frieght (closest store to my house) and bought a tube of clear silicone sealant. When I got back home I wiped off as much as I could and then recoated both lights with oven cleaner. I did this 3 times. Once they were chrome free I ran them under my kitchen sink to remove the last bits of cleaner that I hadn't wiped off. I dried them off with a new microfiber towel and used my air compressor with a nozzle to blast and last water off (I didn't have the patience to let them sit and dry). I noticed that using the brand new microfiber towel it created tiny scratches in the shiny plastic....in retrospect I wonder if you shouldn't wipe them at any point, and instead spray the oven cleaner then use a pressure washer to shoot off the chrome, I really don't know. Additionally I used another brand new microfiber towel to wipe the inside of my clear lens clean and it too scratched the lens, I guess they are made to never be touched? After this I screwed the newly black piece of plastic back into the clear lens. I put the base headlight housing in my vise and ran a bead of clear silicone around the seam. I removed the headlight base from the vise and put the heat gun back in the vise and turned it on. I would heat a small section, vise grip it closed, then moved on to the next section after I let it cool down. I did this all the way around until it was completed then did the other headlight, and installed them both. I also bought new headlight bulbs and fog light bulbs ($20 total off ebay) with the "cool white/blue" look to them instead of the yellow look the halogens produced. Overall I've very happy and impressed. It took me 4 hours-ish but I was simply taking my time. I'm hoping that they are sealed and that I won't have "moisture" issues but we shall see....
Thank you Rob for pointing out that I didn't need to take to a painter, once I found this information out I did the lights within just a few days. I love the look! Thanks for the other people who posted on the forum how-to guides, it's because of the knowledge that you shared that made me do mine! Heres a "few" pictures, enjoy!
Sorry for sideways pics!
#7 ·
I'm not sure what you ordered, I simply ordered cheap bulbs off ebay, so mine were simply unplug old and plug in new. Very easy. The fog lights were a bit more challenging but maybe that's because I have giant hands =)
#8 ·
I ordered these two things from Amazon. I went with the light kit primarily because I’m willing to spend money for quality, and I feel that’s what I’m getting here. That coupled with 5,256 reviews and remaining a 4 of 5 star rating.
https://www.amazon.com/gp/aw/d/B00VNBEBCS#immersive-view_1517191574450
https://www.amazon.com/gp/aw/d/B07486SXW5#immersive-view_1517191627538
I picked up the anti-flicker dongles (for lack of a better term) after reading all over the place about the flicker issues. After seeing your black headlights, I feel like a Project is iminent!!!! I will update the post once I get finished. Should be this week. Lights are supossed to arrive Wednesday!
#9 ·
We don't have canbus lights, so flicker is not an issue. HOWEVER, we DO have DRLs that run the headlights, switching the two sides in series and so halving the voltage on each. This could a) cause the headlights not to turn on (no DRLs), b) cause flicker, or c) Still let them turn on full brightness all the time.
None of those options are optimum. So you can either just remove the DRL relay (essentially the same as option (a) above). OR follow my DRL mod here: Simple reroute DRLs to Foglights mod (for HID users) (note: you'll have to be a member logged in to see photos)
Having said that, I'm EXTREMELY dubious about running LEDs in stock reflectors. I doubt the beam pattern will be any good, and will probably cause horrible glare to oncoming drivers.
#10 ·
At present, I have an RK Sport front bumper. It was on the car when I got it. It’s got some road rash issues and didn’t get any extra support installed when it was put on obviously. Sooooo, I don’t have fog lights or turn signals, which I’m not crazy about. Reroute to fog lights is impossible right now. That said, I would be head over heels in love with this bumper if it had those things on it. I am considering trying to modify the bumper to accept fog lamps and turn signals, but I may go a little custom on it. Ideally something like these
https://drive.google.com/open?id=1tJyYZ0quCGnExXQCpoTsVU1hyjrGvTRZ
Heck, if I try it on the current bumper and it’s not what I want, it’s just practice, I will likely replace the entire bumper anyway. I guess I’ll have to look into a membership to this site. I’m on here all the time now that I have a Solstice!
#11 ·
Wondering if I could polish the oxidation off the inside of my lenses this way...
#14 ·
I inadvertently scratched the inside of the clear lens with very light pressure on a brand new microfiber cloth. I presume that if you can polish the scratchs out then to answer your question, yes this would take off the inside oxidation.....worth a shot, especially if you were to black our your headlights at the same time.
#13 ·
I've always wondered if the OEM black headlights have a black finish on them, or are just unpainted?
When we pick up an 06 several years ago, one of the first things I did was buy a set of OEM black headlamps. After I removed the 06 silver headlamps, I put them in the box that the black headlamps came in. The box itself had foam inside with depressions in the shape of the headlamp so the headlamps don't shift around at all once the box is sealed.
#17 ·
Chop the headlights are actually black plastic with a chrome plastic plating on them that's why you can remove the plating and end up with a black Street Edition type headlight . There are companies out there who actually can replate the "plastic chrome " I've seen ads in some of my car magazines from companies who offer this service especially for people restoring cars .
#15 ·
I have actual street edition headlights on my car.
But 10 years for daily driving has taken its toll.
I’m going to try and take them apart and polish them
#16 ·
Blackbird, if you do it, look to see if the black bezels have a finish on them or if they are just unpainted black plastic, and let me know if you think about it. Thanks in advance.
#18 ·
He is aware of the black plastic on the regular headlights.
He was questioning if on the street edition headlights, GM just didn’t chrome the plastic or if there was a black finish applied to the black plastic.
