Trunk release
1.4K views 24 replies 10 participants last post by  Lou O.
#1 ·
So the other day I was picking someone up. Put all the stuff in the trunk and closed it. Went to start my car….. I closed the trunk with my keys in there. Luckily my glove box was unlocked so I could get them to push the button but what if it was locked? How can I get my keys out then? I was thinking of tying a string to the emergency release and feeding it between the panels to a hidden spot in the cabin unless anyone else has any input.
#8 ·
Many years ago, I loaded up my trunk and shut the trunk with my keys inside. I hadn't unlocked my doors yet. I remembered that there was a removable panel in the rear wheelwell that you can pop out and reach for the emergency trunk release. I couldn't reach it because my bags were in the way. I had to call a tow truck to break in. I must have then hit the switch in the glove box.
Reactions: agent008
#13 ·
I have a 2006. Its pretty loaded. I do not have a release button in the glove box for the trunk.....
Good to know there is a way to get in....Thanks for the post!!
#14 ·
You can add a cable release. There is a forum thread where a member described how he made an emergency release cable that runs into the cockpit behind the drivers left shoulder. It should come up in a search.
You can add your own emergency pull rope using twine or available wire.
You can add a push button by tapping into the release cable actuator. Its behind the cockpit in the trunk
RTE
#23 ·
Okay, would someone please take a cell phone photo of the glove box open showing the button location and post it? I've looked before and could not find it... thanks!
Reactions: wmf246
#24 ·
its the round button top left in the picture below. The glove box is pulled out of the dash to give access to the back side of the button.
RTE
#25 ·
RTE....Thanks, Its directly to the left of the silver bolt (8 or 10 millimeter bolt)??
I'll take a close look when I check up on her in the near future (currently in a storage at a facility)
Reactions: wmf246
