Doc's Street Edition thread
2 reading
7.9K views 124 replies 15 participants last post by  Doc-Z
#1 · (Edited)
I've decided to start a thread for my newly aquired Soulstice Street Edition. At current, I am really (I mean REALLY) car. It handles exceptionally well, it's quick enough (for now) and I love the look.
I'll be using this thread to keep track of any modifications I decide to do on my Street Edition. It will be exceedingly difficult for me NOT to modify the car. When (mainly IF ) I do, it will be things that will either not be outwardly noticable or will be easily reversed. For example, I've already performed my first modification. I doubt anyone would blame me for this, but that factory 2 foot long antenna was really getting in the way of putting the top down. I didn't think swapping out the old one for a 6" antenna would make much of a difference as visuals would go.. . . ..boy was I wrong.
Eventually, I'll be making a shift handle and e-brake out of stabilized wood. I'm not sure when I'll be getting around to this. It will definitely NOT be anytime soon. I have a project car to finish!
Thanks for viewing my thread and for any support, tips, comments and/or criticisms (yes I welcome cirticisms 👈 . . ..this is how we grow)!
#2 ·
Spelled it 2 different ways, there's your criticism. Lol
Car looks good and curious to see how others modded their car so I can get ideas myself.
  • Haha
Reactions: Doc-Z
#8 ·
At least he didn't spell "circumcisions."
A lot of people have done the "stubby" antennae modification. I've never had an issue dropping the top but that's probably because I almost always do it from the drivers side.
Good luck with your mods - look forward to seeing the results!
no pun intended??
  • Wow
Reactions: wmf246
#21 ·
It is a manual trans. I would have assumed (key word there - assume) the knob and boot are seperable. Judging by your post, I'm thinking it will probabby require some motivaiton. If it does take some extra work, I may just have a new boot made with stitching to match the OEM stuff.
I saw what DDM has on their site. I also saw their aluminum shift knob. What I didn't see was an option for orange stitching. There is a local trim shop that I've worked with in the past on various projects for other cars. If I decide to go that route, I'll have them custom make something.. . . ..but there is a LOT of other things I'll need to do, before I get to this point.
A few months ago, I bought a vacuum chamber / pump kit with the intention of making stabilized banksia pod parts for my GTO (banksia pods are sort of like pine cones, but are from Australia). I intend on making a bunch of parts (shift knobs, e-brake handles, as well as steering wheel spokes) for the VX/VZ platform, essentially the Pontiac GTO and Holden CV8 (Z).
#9 ·
in all honesty who even listens to the radio these days? If you want to listen to the radio almost all radio stations stream on either IHeart radio or from their website. There is really no need to have the antenna anyway.
Reactions: wmf246 and MFA
#11 ·
The stock radio has an audio port. I used it to play an iPod. The right iPod can stream though I have not actually done that. I use satellite radio and my iPod via the USB port.
RTE
#27 ·
Congratulations on the find. What a beautiful car!
Interesting. Can you elaborate on that? Stabilized wood?
Why...YES I can.
Roughly 9 or 10 months ago, I purchased a vacuum pump and 5 gallon chamber. My intent was to (eventually) make some parts for my GTO. Specifically a shift knob, e-brake handle and either make a stabilized wood topped steering wheel or steering wheel spokes for my GTO. I also imported numerous banksia pods (which are sorta like pine cones) from New Zealand.
(I would upload a picture, but the forum has that blanked out...so that isn't happening right now)
Anyway, to stabilize wood, you soak the wood in a resin bath and pump the air out. When the vacuum is released, the air within the wood is replaced (impregnanted) with the resin. Depending on what type of resin you use (can harden over time, with heat, etc.) will cause the wood to become very stable. During the stabilization process, you can choose to use various dyes to either enhance the color of the wood, of completely make the wood a unique color (green, purple, red, orange, etc.). There are limitation of the dye, but depending on the dye you use, how long you vacuum the air out of it and whether or not you sand the surface down, will allow you to dye it more than just the one color.
Once the wood is stabilized, most or all of the air gaps within the cellular structure are gone. These air gaps are what allow for the wood to expand or contract with temperature and humidity. The air gaps also (over time) cause the wood to crack. When the wood is stabilized, it could last for decades or much much longer.
When used for gear shift knobs, the heat cycles of the sun of an interior will cause the wood to degrade and crack. The stabilization will help this last longer. Plus, I can impregnate the wood with black / orange and red dye.
#18 ·
By the way. This (rather expensive) antenna works perfectly and has increased the reception range for my car which had an aftermarket ~ 17" antenna.
#28 ·
I suggest buying a used Solstice shifter to modify, and store the OEM away. Over the years there's been a lot of talk about removing and replacing the OEM manual knob, however I'm not having any luck on finding a thread that documents how it's precisely accomplished.
$126 + $35 S/H = $161
Manual Transmission Shifter Assembly Floor Mount Fits 06-08 Pontiac Solstice OEM | eBay
@cammerjeff might be able to give pointers on how to remove the manual shift knob. See his post and pics in this thread. He cut off the manual shift knob in order to install it on a Tremec 6 speed for his V8 conversion.
#29 ·
https://www.solsticeforum.com/threads/remove-a-stock-gearshift-knob.160642/
At $59 the DDM shift adapter will be cheaper and will still allow the OEM shifter and boot to be kept intact. I suppose a shift boot can be made to order by an upholstery shop fornleass than $100?
#31 ·
You're right about the rattle. I only managed to fix my shifter rattle when I had a shift rod made that would plug into the lower half of the OEM shifter rod -- it is one rod inserted into another, with a bit thick plastic/rubber bushing between the two that I imagine absorbs the vibrations.
#32 ·
I like the rattle. I have a JPM shifter with a custom Armor Branch knob Joe made for me. It’s got a resonate frequency in second and third.
RTE
#34 ·
Another way is to add a heavier knob. It moves the frequency out of the range where it exhibits in normal driving
RTE
#38 ·
To make the car legal in Illinois, I had to remove the tint from the headlights, fogs/turn signals. I still have to dothe tail and backup lights, but this was really annoying.
BEFORE:
AFTER:
I like the after, my girlfriend like the before. I personally, like being able to see at night and not having to use my high beams in order to see the road.
#44 ·
Did I mention I like the rattle?
Acceptance makes life so much easier and less stressful
Lesson learned from 53 years of marriage.
RTE
#46 ·
#48 ·
I wasn't happy with the job I did on the passenger headlight, so I removed it and started over.
I managed to find a G.M Performance Parts Kappa intake from a guy in Rapid City, S.D.. I got this for (what I thought) was cheap.
I'm not sure if I want to install it, or put it on the side and wait for it to become more desirable. It is in really good shape.
I had one of these in my G5. I can't say whether or not it did anything. It did look better IMO and made the engine sound better. As far as added H.P.; I would be hard pressed to say yes to that. For what I paid for it, it would look nice in a frame on the wall next to the car.
#49 ·
I vote you slap it on and enjoy it brother. You only live once!
Its only true value is in that CARB sticker for folks that live in California.
Many others have noted the benefit (as you noted) is looks and sound. No real HP gains to be expected.
I will warn you to be gentle on the clamps as the thin pipe GM provided collapses pretty easily under torque. At least they did on the GMPP one i have on my GXP.
